Thread Number: 31777
Note: Neutral Grounded to Cabinet |
Post# 479346   12/4/2010 at 13:21 (4,884 days old) by PeterH770 (Marietta, GA)   |   | |
When you open up a dryer to connect a proper, new 30 amp power cable (3 prong) and you see a note next to the connection point that says neutral is grounded to the cabinet, along with a cable from the central neutral point to the block, is this something that should be changed, or do you just need to make sure the cabinet is properly grounded?
Post# 479347 , Reply# 1   12/4/2010 at 13:29 (4,884 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 479360 , Reply# 2   12/4/2010 at 14:45 (4,884 days old) by Unimatic1140 (Minneapolis)   |   | |
Post# 479370 , Reply# 3   12/4/2010 at 15:09 (4,884 days old) by Toggleswitch (New York City, NY)   |   | |
A proper new 30a cable................
Actually, the law (in the United States) now requires a 4-prong, 4-cable dryer outlet and cord in NEW installations (homes). The old way... a three-prong, three-conductor cord may still be used when such an outlet (i.e. with only three "holes") is already exisitng. If you were to upgade your receptacle (female) to the new 4- conductor, 4-prong, 4-hole style outlet, then: #1= hot (black or red) #2= neutral (white) #3= hot (The OTHER hot. i.e. if black is on "1", then red) #4= Screw to chassis/cabiet. New 4th green/ground wire from flexible connector/cord would go here. Loop between 4th screw for ground and neutral terminal "#2" would be removed. It is my understanding that in Canada 3-wire connections of electric (220v) clothes dryers with a shared neutral /ground is not permitted and has not been so since 1966, if ever. I remember this from installation instructions that came with my mother's Maytag dryer of that vintage. |
Post# 479408 , Reply# 4   12/4/2010 at 17:33 (4,884 days old) by PeterH770 (Marietta, GA)   |   | |
