Thread Number: 31812
DRYERS |
Post# 479726   12/5/2010 at 22:45 (4,888 days old) by lebron (Minnesota)   |   | |
Post# 479729 , Reply# 1   12/5/2010 at 22:56 (4,888 days old) by qsd-dan (West)   |   | |
Post# 479731 , Reply# 2   12/5/2010 at 23:01 (4,888 days old) by Pulsator (Saint Joseph, MI)   |   | |
... the real question is WHICH Whirlpool dryer?!
My vote goes to the 27 inch machine. I love the way mine performs, it has never missed a beat, I think the skinnier cabinet design is more attractive, and I think it handles bulky things like comforters and sheets like no other! I actually refuse to use the 29 inch machine in my mom's laundry room now because I feel that stuff doesn't come out as soft and it doesn't seem to dry as evenly, especially bulky items. (The 29 inch machine does have the "accudry" moisture sensor too and still not up to par in my eyes.) |
Post# 479771 , Reply# 5   12/6/2010 at 01:06 (4,888 days old) by PeterH770 (Marietta, GA)   |   | |
I grew up with a Kenmore. Never thought about it much until I bought a GE as my first dryer -- and loved it!!! Clothes were fluffier and less wrinkled coming out of the GE, and it dried much faster. I thought GE was the cat's meow until I got a 1-18 dryer, hand's down the best! And now, the Hamilton: time will tell...
So the moral of the story is: to each his own... |
Post# 479855 , Reply# 7   12/6/2010 at 11:53 (4,888 days old) by turquoisedude (.)   |   | |
I guess I tend to favour GE dryers since I have owned more of them (well, and GE clones like the Eaton's Viking) than any others. I always found them to be good performers, easy to operate and relatively easy to work on and find parts for.
I may change my mind when I finally snag a Frigidaire dryer to go with that Deluxe washer of mine, though... LOL |
Post# 479928 , Reply# 8   12/6/2010 at 17:47 (4,888 days old) by KenmoreGuy64 (Charlotte, NC)   |   | |
I have two dryers right now - a 1978 Kenmore 60 series with three heated timed dry only cycles, and no wrinkle guard. I bought this dryer used in 1990 for my sister and put it in service for myself in 2006. The other dryer is my 1986 Kenmore Fabric Master that I bought new.
The two machines are mechanically essentially identical - same heating element, same rear bulkhead, same motor, rollers, belt, yada yada. The '86 outperforms the '78 in wrinkle-free performance, in speed, and in dryness consistency. I can't fault the '78 since it's timed dry only - if I don't set quite enough time the load won't be fully dry. But, given two comparable loads and two identical pair of Levis, the one in the 86 will come out unwrinkled whereas the pair in the 78 may be a little iffy... I am not sure why this would be, however the timed dry cycles and the temps provided by the thermostats in each dryer may have a bearing on this, as well as each dryer's venting. One vents a further distance than the other. Overall, for flawless drying, I am very happy with both but the '86 leaves no worries every time. Gordon |
Post# 479952 , Reply# 10   12/6/2010 at 20:49 (4,887 days old) by alr2903 (TN)   |   | |
I will always like the whirlpool designed 29" machine with the filter that slides out of the top. I think the filter is much larger than any other offered. My family are all true fan's of the "hamper door". alr2903 |
Post# 480027 , Reply# 13   12/7/2010 at 06:48 (4,887 days old) by cycla-fabric (New Jersey (Northern))   |   | |
I have to agree with most here that the Whirlpool family of dryers are the best. We grew up with Kenmore dryers and they were dependable and got the job done quickly. I now have both a Maytag and a Whirlpool dryer and the Whirlpool beats the Maytag hands down and getting the job done right. There is nothing wrong with the Maytag, it does it job, but I feel it overdrys most things, and it is consistant on how long it takes to dry a load - 45 to 50 minutes on Reg or Permanent Press when drying lightweight items - way too long. So since those items are always overdryed and I now use the damp dry cycle to dry light weight items as it will almost dry them on this cycle, and it is much shorter about 20 minutes. So saying that, it's nice to have a choice of dryers to use and overall the Whirlpool dryer is used more often and makes the best dryer in my opinion.
Doug |
Post# 480041 , Reply# 14   12/7/2010 at 07:36 (4,887 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
WP has certainly had the best dryers since the interduction of the stationary bulkhead models that came out in 1966. Overall I would rate the WPs & KMs excellent in all major aspects of performance, durability and repairability. The MT HOHs suffered with long vents too small a lint filter and drum. They also gave no temperature choice or worse yet dryness selections on electronic sensor models. The later SOH models were much better overall but had blower and airflow problems which weren't really ever addressed until they came out with the 27" line in the mid 1990s. The GEs, WHs and Frigidares all suffered with very high rear drum temperatures if used on long vents or again when drying very linty loads where the too small lint filters would clog so fast as to restrict air flow. The Frigidare 1-18s did work much better but had durability and noise problems and were a pain in the neck to fix. The 27" WPs are well built generally good performers but they just dry as fast as the 29" machines. I also an not that impressed with any 27" machines that I have used for drying large loads of jeans etc they just come out more wrinkle free with a larger diameter drum.
Post# 480259 , Reply# 15   12/8/2010 at 04:48 (4,886 days old) by chaskelljr2 (Washington, D. C.)   |   | |
Did you ever had a Whirlpool/Kenmore Dryer with a Solid-State Sensor in your collection??? Had you ever used such a model before??? If so, what is the difference between "Solid-State" and "Fabric-Master"??? --Charles-- |
Post# 480626 , Reply# 17   12/9/2010 at 20:37 (4,884 days old) by washerlover (The Big Island, Hawai’i)   |   | |
I've found that the Norge/Wards gas dryers circa 60s-70s were best in drying time, though they run hot, but dry the fastest. Just make sure the seal is good around the door, because the fan blows like a hurricane, and lint blows out around the dryer door like crazy! I also have to add that they are extremely quiet.
