Thread Number: 3184
Duet not Cleaning |
Post# 81305 , Reply# 1   9/2/2005 at 10:24 (6,808 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Washing is a chemical process as you probably know, there three variables that contribute to the cleaning of laundry: Chemical action, Mechanical action and Temperature. Together with time you have the factors involved in laundry cleaning. There are also a few other things important like the quality of your water and if your washer is functioning properly and kept clean. A few questions: What detergents did you use and how much? How hard is your water? Are you on city water or on a well? What cycle and what temperature do you use to wash towels? Is your washer smelling? Do you keep the door open after doing laundry? Are you letting your towels dry after you used them or do you just throw them on a pile? Is your washer working properly? Just a few questions I can think of. Louis |
Post# 81307 , Reply# 2   9/2/2005 at 10:38 (6,808 days old) by toggleswitch (New York City, NY)   |   | |
I am assuming, of course you let the towel dry thoroughly before putting it in the hamper. From my days of having to dry stowels on a rack (when I rented 8+/- yeasr ago) IMHO once they go "sour" you just cant get that smell completely out, EVER. I've tried warmest water permissible and every chemical additive under the sun, inluding a super-hot super-long bake-to-kill-all germs dry. NADA The best additive I have found BTW (IMHO) was the Febreeze LIQUID that was made to go in the washer. The slight secnt was very light and agreeable, and it did what it said,.. eliminated laundry odors. I can no longer find it in this market, however. Try a new set of towels and see if it is the towels themselves or the machine. |
Post# 81308 , Reply# 3   9/2/2005 at 10:38 (6,808 days old) by toggleswitch (New York City, NY)   |   | |
Post# 81326 , Reply# 4   9/2/2005 at 12:58 (6,808 days old) by jmirawm (Barling Arkansas)   |   | |
Last time I was out shopping, I noticed that they have TIDE with Febreeze. |
Post# 81329 , Reply# 5   9/2/2005 at 13:12 (6,808 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Febreeze isn't the solution if the laundry comes out smelly. That means the laundry isn't clean and that is what should be solved. Not covering up the smelliness. A higher water level isn't particularly necessary as long as the washer works properly. Modern frontloaders are designed to clean with low water levels and it works as long as the laundry is thoroughly saturated. I can understand when you would want to raise the water level in the rinse part of the cycle, but an extra rinse can compensate for that. |
Post# 81332 , Reply# 6   9/2/2005 at 13:48 (6,808 days old) by RE563 (Fort Worth, Texas)   |   | |
Post# 81333 , Reply# 7   9/2/2005 at 13:59 (6,808 days old) by Spiraclean (UK)   |   | |
Hi Michael, The sour smell you refer to is caused by bacteria on the laundry. Have you tried adding liquid Chlorine Bleach to the wash? Do you use Fabric Softeners? These can cause a greasy slime like build up to form inside the washer this provides a perfect environment for bacteria and mould to grow. I would also recommend you run a hot whites cycle with no laundry and add a cup of Chlorine Bleach to the wash cycle, this will help to remove the slime build up and also kill any mould and bacteria that may have built up in the machine. I hope this helps. All the best. Hugh |
Post# 81340 , Reply# 9   9/2/2005 at 14:52 (6,807 days old) by rayjay (Carteret, New Jersey)   |   | |
Chlorine Bleach WILL solve this. IF the towels are dark colors, juat add a 1/4 of a cup. If they are lighter in color add a liile more. |
Post# 81344 , Reply# 10   9/2/2005 at 15:29 (6,807 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 81375 , Reply# 11   9/2/2005 at 22:24 (6,807 days old) by westyslantfront ()   |   | |
Every so often, I run my washer and also my dishwasher empty...no clothes or dishes....with Clorox and it seems to elimate odors. I also leave lid/door open so that machine can air out. |
Post# 81403 , Reply# 14   9/3/2005 at 06:23 (6,807 days old) by Toggleswitch (New York City, NY)   |   | |
Some benefits of the previously suggested pine oil treatment: 1) Disinfects. 2) Leaves a nice mild smell even after dryer. (when used in SMALL doses). 3) Cuts the suds level greatly. Too much detergent and suds prevents a F/L from doing its job, as we all know. 4) Said to clean also on the spiritual level. Great for when major illnesses, depression, negativity etc. are in the house. Great for those times when you have to use a public machine. |
Post# 81405 , Reply# 15   9/3/2005 at 06:27 (6,807 days old) by Toggleswitch (New York City, NY)   |   | |
BTW is the drain hose a short and direct run? If the machine has to pump up or horizontally for a long distance, a check-valve in the drain hose (as close to the machine as possible) will prevent contaminated water from seeping back into the tub. This may be cross-contaminating the water from one of the cycle phases to the other. |
Post# 81822 , Reply# 18   9/6/2005 at 08:07 (6,804 days old) by toggleswitch (New York City, NY)   |   | |
Post# 81853 , Reply# 19   9/6/2005 at 15:43 (6,803 days old) by Michaelman2 (Lauderdale by the Sea, FL)   |   | |
No Toggle...had not even thought about that...hummm...this may still require a service call...I am about as handy as nothing..thanks for the heads up though! |
Post# 81984 , Reply# 20   9/7/2005 at 05:31 (6,803 days old) by kenmore1978 ()   |   | |
adding some sudsy ammonia to the wash |
Post# 81991 , Reply# 21   9/7/2005 at 06:32 (6,803 days old) by toggleswitch (New York City, NY)   |   | |
Post# 82496 , Reply# 22   9/9/2005 at 14:56 (6,800 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
