Thread Number: 31929
Speed Queen wringer washer guts |
Post# 481359 , Reply# 1   12/13/2010 at 11:38 (4,881 days old) by wringersteve ()   |   | |
The wringer and tub have been removed |
Post# 481361 , Reply# 2   12/13/2010 at 11:40 (4,881 days old) by wringersteve ()   |   | |
I was surprised to find the innards as clean as they were! I'll replace the gasket and do a little touch-up painting with Rustoleum appliance epoxy around the bottom inner lip. |
Post# 481391 , Reply# 3   12/13/2010 at 12:53 (4,881 days old) by mickeyd (Hamburg NY)   |   | |
Post# 481411 , Reply# 4   12/13/2010 at 14:12 (4,881 days old) by rollermatic (cincinnati)   |   | |
Post# 481535 , Reply# 6   12/13/2010 at 22:14 (4,880 days old) by wringersteve ()   |   | |
Here is a better pic. |
Post# 481536 , Reply# 7   12/13/2010 at 22:16 (4,880 days old) by wringersteve ()   |   | |
One angle. |
Post# 481538 , Reply# 8   12/13/2010 at 22:18 (4,880 days old) by wringersteve ()   |   | |
from a different angle. |
Post# 481549 , Reply# 9   12/13/2010 at 23:35 (4,880 days old) by mickeyd (Hamburg NY)   |   | |
Post# 481639 , Reply# 10   12/14/2010 at 11:42 (4,880 days old) by rollermatic (cincinnati)   |   | |
Post# 481850 , Reply# 12   12/15/2010 at 11:58 (4,879 days old) by mickeyd (Hamburg NY)   |   | |
Post# 880561 , Reply# 15   5/13/2016 at 10:36 (2,903 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
IIRC a member in upstate NY had a late model SQ wringer that needed a new home, and said that unit's pump didn't work correctly from the start. That was a new or nearly so unit, again IIRC.
You would think that SQ kept making wringers almost as long as Maytag more spare parts could be had NIB, but that does not seem to be the case. Meanwhile Maytag stuff is all over the place. |
Post# 880571 , Reply# 17   5/13/2016 at 11:16 (2,903 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
While things may have varied locally in order of sales Maytag, Speed Queen then Kenmore dominated conventional washer sales. May have the order of last two switched, but you get the point.
This probably explains why models from those three brands of all vintages are the most commonly found today. Maytag of course had a national sales force that stretched from Maine to California. Kenmore via Sears either stores or catalog pretty much the same. Thing about SQ wringers is the largest model held a huge amount of laundry. Something like 14 lbs. I also like the fact SQ's tub does not have exposed bolts like Maytag and some others. The whole SQ saga is discussed here: www.automaticwasher.org/cgi-bin/T... Joe Barlow and John Seelig as Barlow & Seelig Manufacturing, then McGraw Edison, next Raytheon, then Alliance Laundry systems. en.wikipedia.org/wiki/Speed_Quee... Have seen early SQ wringers (with jade green enameled tub) and they look rather interesting. |
Post# 881395 , Reply# 18   5/18/2016 at 23:12 (2,897 days old) by rollermatic (cincinnati)   |   | |
