Thread Number: 31980
Rebuilding Westinghouse laundromats |
Post# 482143 , Reply# 1   12/16/2010 at 18:38 (4,877 days old) by christfr (st louis mo)   |   | |
OH REALLY......WELL... you have 2 sets?? whats up with that? personally i think you should keep the older set the ones with the blue trim on the doors those are so pretty and that one i did feel up it has a good changer. anyway a long time ago greg sent me on a search for a boot for mine its some sort of frigidaire boot that you have to retro fit into the machine. ill do some looking online to see if i can find it again. your gonna have fun with that baby she has to come all the way apart but it does work and whey are wonderful washers. hugs
Post# 482151 , Reply# 3   12/16/2010 at 19:08 (4,877 days old) by christfr (st louis mo)   |   | |
just had to come off with an attitude ha ha to fun.. if you like the older set thats just fine. mine was dead when i got it too im sure for starts a timer is needed ill have to ask paul where he got his. stick you hand into the drum and turn it it should turn clock wise then try and turn it counter clock wise and see if the drum stops, your checking the prawl in the changer.
Post# 482277 , Reply# 4   12/17/2010 at 07:34 (4,876 days old) by christfr (st louis mo)   |   | |
Post# 482473 , Reply# 6   12/18/2010 at 10:02 (4,875 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The SF washers were all 30" wide except the SF combos that we have are 32" in width. All the SF washers do use the same water pump kit with slight adjustment to the drive spring length. The original pump bodies were case pot metal and then were changed in the 1950s to black Bakelite plastic,then in the early 1970s they went to white polypropylene plastic I don't know the exact years of these changes.
Post# 482503 , Reply# 7   12/18/2010 at 13:43 (4,875 days old) by 3beltwesty ()   |   | |
For clairity; Does this mean a 3 belt westy; ie 5300165317 Q165317 pump fits a slant front washer? It is in these instructions in mentions lengthening the distance when used on a 30" model. |
Post# 482508 , Reply# 8   12/18/2010 at 14:08 (4,875 days old) by 3beltwesty ()   |   | |
5300165317 pump for Oval potato pulley machines |
Post# 482560 , Reply# 11   12/18/2010 at 19:12 (4,875 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 482561 , Reply# 12   12/18/2010 at 19:12 (4,875 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 482562 , Reply# 13   12/18/2010 at 19:12 (4,875 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 483071 , Reply# 15   12/21/2010 at 00:25 (4,873 days old) by Travis ()   |   | |
Here are my new babies. The tub won't turn in either direction. :-( It feels so satisfying to match them up. |
Post# 483229 , Reply# 16   12/21/2010 at 17:48 (4,872 days old) by christfr (st louis mo)   |   | |
Post# 483235 , Reply# 17   12/21/2010 at 18:24 (4,872 days old) by Travis ()   |   | |
Ok, I ordered a couple boots and a couple pumps. Chris, where can I get these painted? |
Post# 483237 , Reply# 18   12/21/2010 at 19:05 (4,872 days old) by christfr (st louis mo)   |   | |
Post# 483410 , Reply# 19   12/22/2010 at 09:39 (4,871 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 483425 , Reply# 20   12/22/2010 at 10:52 (4,871 days old) by Travis ()   |   | |
I ordered that Frigidaire boot that was mentioned above. I had chased the Westinghouse boot for a couple years and gave up. |
Post# 483442 , Reply# 22   12/22/2010 at 11:53 (4,871 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 483463 , Reply# 23   12/22/2010 at 13:20 (4,871 days old) by 3beltwesty ()   |   | |
Here are some old boot part numbers and models they fit CLICK HERE TO GO TO 3beltwesty's LINK |
Post# 483469 , Reply# 24   12/22/2010 at 13:29 (4,871 days old) by 3beltwesty ()   |   | |
Another boot is the Q4689; the link to this same site says it fits spacemates CLICK HERE TO GO TO 3beltwesty's LINK |
Post# 483605 , Reply# 29   12/22/2010 at 20:05 (4,871 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 483729 , Reply# 30   12/23/2010 at 10:00 (4,870 days old) by 3beltwesty ()   |   | |
New Way to wash clothes in 1954! |
Post# 483732 , Reply# 31   12/23/2010 at 10:11 (4,870 days old) by 3beltwesty ()   |   | |
Complete agitation. More from Betty |
Post# 483734 , Reply# 32   12/23/2010 at 10:27 (4,870 days old) by 3beltwesty ()   |   | |
Betty hawking more washers! |
Post# 483778 , Reply# 34   12/23/2010 at 13:37 (4,870 days old) by 3beltwesty ()   |   | |
ONLY 3.15 dollars per week! |
Post# 483781 , Reply# 35   12/23/2010 at 13:48 (4,870 days old) by mrb627 (Buford, GA)   |   | |
Post# 483827 , Reply# 36   12/23/2010 at 16:42 (4,870 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 483829 , Reply# 37   12/23/2010 at 17:07 (4,870 days old) by 3beltwesty ()   |   | |
Betty has 2 Stars CLICK HERE TO GO TO 3beltwesty's LINK |
Post# 483831 , Reply# 38   12/23/2010 at 17:16 (4,870 days old) by 3beltwesty ()   |   | |
The link here has a behind the scenes image before a Westinghouse commercial. Betty got paid about 100K per year in 1950 by westinghouse CLICK HERE TO GO TO 3beltwesty's LINK |
Post# 483832 , Reply# 39   12/23/2010 at 17:24 (4,870 days old) by 3beltwesty ()   |   | |
about the same stage CLICK HERE TO GO TO 3beltwesty's LINK |
Post# 484193 , Reply# 40   12/25/2010 at 09:33 (4,868 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 484194 , Reply# 41   12/25/2010 at 09:39 (4,868 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 484592 , Reply# 42   12/27/2010 at 15:29 (4,866 days old) by Jeff_adelphi (Adelphi, Maryland, USA)   |   | |
Post# 484600 , Reply# 43   12/27/2010 at 16:11 (4,866 days old) by 3beltwesty ()   |   | |
This boot is still at some places as new old stock. They show up on ebay too several times per year. There are pockets of old parts that require hunting. |
Post# 484749 , Reply# 44   12/28/2010 at 11:08 (4,865 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
This is an old picture of my Twins. The dryer is in storage now and the washer is resting for a while but they are fun.
I used the 5303261132 gray boot on this machine and it worked OK. When I heard they were discontinued a while back, I bought one on ebay for a spare. Wow - that room looks completely different now, what a difference! |
Post# 484861 , Reply# 45   12/28/2010 at 19:41 (4,865 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 484894 , Reply# 46   12/28/2010 at 22:21 (4,865 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 484895 , Reply# 47   12/28/2010 at 22:22 (4,865 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 484904 , Reply# 48   12/28/2010 at 23:20 (4,865 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 484905 , Reply# 49   12/28/2010 at 23:23 (4,865 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 485015 , Reply# 51   12/29/2010 at 13:56 (4,864 days old) by 3beltwesty ()   |   | |
Ebay prices on this "stuff" can be a lot higher or lower than a parts house. There is a lot of new old stock that pops up and items that have been NLA at parts houses often resurface on Ebay 5 or 10 years later. |
Post# 485068 , Reply# 52   12/29/2010 at 19:41 (4,864 days old) by Travis ()   |   | |
I nabbed it. I had been watching. |
Post# 485293 , Reply# 53   12/30/2010 at 16:54 (4,863 days old) by 3beltwesty ()   |   | |
Cool; glad another collector got a spare boot! CLICK HERE TO GO TO 3beltwesty's LINK |
Post# 485536 , Reply# 56   12/31/2010 at 17:54 (4,862 days old) by austinado16 ()   |   | |
Yep, that's the grey boot that I originally used to restore my LB-6. Glad someone here nabbed it! IIRC, my LB-6 has a round pulley. I don't recall seeing it look oval when running. This post was last edited 12/31/2010 at 20:54 |
Post# 485552 , Reply# 60   12/31/2010 at 18:53 (4,862 days old) by 3beltwesty ()   |   | |
DIAGRAM |
Post# 485943 , Reply# 62   1/2/2011 at 22:08 (4,860 days old) by spin-it ()   |   | |
What can you tell me about the Westy Tall Tumbler? Looks like a cool machine. What years were they built? Do thet have the same 3 belt drive system and components as the SF? |
Post# 486886 , Reply# 63   1/7/2011 at 00:15 (4,856 days old) by neptunebob (Pittsburgh, PA)   |   | |
How could you possibly have a Westinghouse washer from 1976 without it being a pile of rust? Every time I have seen one in the garbage I notice that the cabinet is badly rusted to the point of holes - They even earned the name Rustinghouse. It just seems like a poor design with thin metal that trapped moisture that was not improved until the Frigemore came out.
It seems that the 1950s laundromats were much less prone to rust. Or is that because all we see here are restored machines? |
Post# 487158 , Reply# 76   1/7/2011 at 21:52 (4,855 days old) by 3beltwesty ()   |   | |
One is suppose to have the washer on its back and place the basket in vertically. Here I just used a 1x2 and pushed the tub down and placed the basket in horizontally |
Post# 487160 , Reply# 77   1/7/2011 at 21:55 (4,855 days old) by 3beltwesty ()   |   | |
westy e ring |
Post# 487162 , Reply# 78   1/7/2011 at 22:00 (4,855 days old) by 3beltwesty ()   |   | |
The roller bearing needs a good contact type high pressure grease |
Post# 487167 , Reply# 79   1/7/2011 at 22:11 (4,855 days old) by 3beltwesty ()   |   | |
Here is where I once screwed up. I used a HUB piece that was the old 29 year one and the went through a few clutch springs and a potato pulley too |
Post# 487173 , Reply# 80   1/7/2011 at 22:22 (4,855 days old) by 3beltwesty ()   |   | |
the Spin belt was drawn in |
Post# 487182 , Reply# 83   1/7/2011 at 22:57 (4,855 days old) by 3beltwesty ()   |   | |
Booting up |
Post# 487190 , Reply# 87   1/7/2011 at 23:26 (4,855 days old) by 3beltwesty ()   |   | |
before intalling the door test out the tub lamp! |
Post# 487202 , Reply# 91   1/8/2011 at 00:06 (4,855 days old) by 3beltwesty ()   |   | |
This is the washer I left off at first, it caused the slinky spring to get goofed up. It took a mess of time to find this missing washer, then once it was on the machine had no issues with the springs |
Post# 487263 , Reply# 92   1/8/2011 at 10:17 (4,854 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
3belt, I learned a lot , my 1957 sounds like it has bad bearings but when I heard your machine I am now thinking its the shaft and not the bearing, it sounds the same!
I will check and see if that shaft fits my 1957 3 belt for a refit! My bearings may be good after all since the original owner replaced them three times in its working life. Love the Mardi Gras colors I have a 1918 Easy painted the same way! |
