I got the pump my Whirlpool washer MD#LTA5605E0 and installed it. Everything seemed to working then I noticed a leak. I drained the washer and check to make sure the hose were on securly and the pump proctector is also secure. I brought the suds water back into the washer and after a few minutes the leak was there again. I looked with a flash light and the water seems to coming from the bottom of the pump protector. I have another Whirlpool model number LPA7805W2 can I put that pump protector on to the other washer? Or any other suggestions. Thanks for any help and Happy Holidays.
I found the leak, the water is dripping from the hose attached to the side of the tub. Tommorow I will try tighting the clamps, the screws may be loose.
