Thread Number: 32272
Holiday Bobloads
Post# 486702   1/6/2011 at 08:12 (4,848 days old) by dj-gabriele ()
Hi guys!
Here in Italy today is the last day of the Christmas holidays, Epiphany here called Epifania or better Befana (the old lady that brings coal to bad children and sweets to good ones, descending from the chimney and leaving them in socks), tomorrow everyone still on vacation is going back to work and students are going back to school.
We celebrated (again) preparing a overly "energetic" lunch and so managed to fill 3 dishwashers at full load: this was the one comprising the biggest quantity of baked on pans and stuff. Let's see if the machine can cope with the dirt!
The machine is a new SMEG LSP1449N under-counter dishwasher (not built-in), nothing exceptional, that I presented you a few months ago when we bought it (at the time it was still on the balcony covered in its plastics, we finished renovating and now it found its place in the kitchenette.
On this first picture you can see the lower rack and the door, we don't rinse anything and scrape only major debris from our dishes, everything just goes right in the machine.
Post# 486705 , Reply# 1   1/6/2011 at 08:20 (4,848 days old) by dj-gabriele ()
On this second picture you can see the upper rack and what's beneath the top layer of stuff: glasses and utensils, on the sides we put a couple of small not too dirty cups.
Some more information about the machine: it holds 14 place settings and the lower rack is of the open-space kind, the cutlery bin can be positioned anywhere on the machine or removed altogether as there are cutlery holders on the sides of the top rack too. The cutlery bin shown here is from a 45 cm SMEG dishwasher as we wanted another one to keep on the sink till we filled it and alternate it to the main one.
The water usage of the machine is 13 liters on most programmes, if you add prewash (by pressing the first button, all the cycles are modified adding it except the "bio" cycled, used here that becomes the energy saving cycle and the one used to calculate the energy ratings for the Eurolabel, it lasts 3 hours and only has one rinse and a purge, we never use it. With said cycle the energy use is 1,06 kWh.
With the BIO cycle that we use most often the energy use is only 1,2 kWh and lasts only 100 minutes and has 2 real rinses.
Post# 486708 , Reply# 2   1/6/2011 at 08:30 (4,848 days old) by dj-gabriele ()
On this last picture you see the front of the machine and a zoom of the left part of the control panel, where you select the cycles.
For this load I used BIO cycle that is fairly quick and does a nice job while using so little energy.
THe machine can be hooked to hot water up to 60°C but given that a single fill is just a little more than 3 litres, there's no time for hot water to arrive to the faucet, even with a circulator pump, that it has stopped loading so it simply is a waste as water has to be heated two times!
Now we only have to wait, I'm going to post the results of the wash as soon as the machine has finished!
Oh, we used Finish "power powder" and separate salt and rinse aid as they achieve the best possible result!
Oh, BTW, on the left you can see a quite rare Italian 20 ampere 230V outlet fitted with a slim 16A plug!
That's cool as that's the only outlet I know that can deliver a whopping 4600W of power to a "standard" appliance should it require it... but given our electric contract is only 3 kW... that won't ever happen ;)
Post# 486723 , Reply# 3   1/6/2011 at 10:00 (4,848 days old) by joe_in_philly (Philadelphia, PA, USA)
joe_in_philly's profile picture
Very interesting dishwasher. I like the fold down cutlery trays in the upper rack -what a great idea.
I am curious as to what you mean by "our electric contract is only 3kW." Is that the maximum amount of electricity you are able to use at one time?
Post# 486735 , Reply# 4   1/6/2011 at 10:54 (4,848 days old) by Iheartmaytag (Wichita, Kansas)
iheartmaytag's profile picture
Is that door resting on/pivioting on the cord?
That could lead to shocking results.
Post# 486739 , Reply# 5   1/6/2011 at 11:09 (4,848 days old) by dj-gabriele ()
RESULTS RESULTS!
Both lower and upper rack were nice cleaned and dry!
Only one thing came out dirty, it was the pan in which the roast was cooked: half an hour on the stove and then 2 hours in the oven at 200°C
Have a look at the pictures!
Post# 486741 , Reply# 6   1/6/2011 at 11:10 (4,848 days old) by dj-gabriele ()
More photos:
This is what was under the things on the top rack, everything was sparkling clean
Post# 486742 , Reply# 7   1/6/2011 at 11:12 (4,848 days old) by dj-gabriele ()
THE OFFENDING PAN
Here you can see a detail of the pan that remained dirty!
Honestly that's very minor dirt for something that was baked for two hours on high heat after having been cooked on the stove!
Too bad I didn't take a "before" picture, it was gross...
Post# 486743 , Reply# 8   1/6/2011 at 11:18 (4,848 days old) by dj-gabriele ()
Now, answering the questions
@ joe_in_philly
Yup, with a tolerance of 10%, plus a "grace period" of 10 minutes when we can use up to 4 kW of power, that is useful when the oven is on "fast pre-heat" as it draws 3,3 kW, otherwise the meter trips (it trips anyway at least twice a week anyway).
Now we're going to upgrade to a 6kWh contract as we can't cope anymore with the standard one. (oh mind that in Italy electricity is the most expensive in all the western world, that's why contracts are so small compared to other countries)
@ Iheartmaytag
No, there are 5 cm of space beneath the machine as the pedestal is recessed and the wooden trimming is cut lower for the door to open smootly
Post# 486753 , Reply# 9   1/6/2011 at 12:44 (4,848 days old) by joe_in_philly (Philadelphia, PA, USA)
Gabriele,
That is so interesting. I have never heard of anything like that before.
Where I live, in Philadelphia, we don't have anything like that. In the past, during the summer, the rate of electricity was tiered with the first 500 kWh per month at one rate, and anything over at a slightly higher rate. The only way to know how much power you have consumed in any particular month would be to go outside and look at the power meter. As a part of a several year plan to deregulate electicity in Pennsylvania, we now have the ability to choose our power generator. Starting in 2011, in Philadelphia we have many companies to choose from, with different rates and contracts.
Joe
CLICK HERE TO GO TO joe_in_philly's LINK
Post# 486821 , Reply# 10   1/6/2011 at 18:05 (4,848 days old) by gorenje (Slovenia)
gorenje's profile picture
Hello Gabriele,
is this a "norm" for the whole Country? (Italy) How can you use 2 major appliances at the same time? I guess you can't.
I can turn on virtually all my appliances at the same time and nothing happens. The power won't shut off.
Ingemar
Post# 486823 , Reply# 11   1/6/2011 at 18:15 (4,848 days old) by nrones ()
Why not use appliances on same time?
Here, I am preparing for a holiday now, and at once washer, dishwasher, dryer, and boiler were on, and nothing happend... why would power swich off... I remember when I was quite young, and when we turned the washer and dishwasher on, fuse would blow, but then we"ve just changed fuse from 12A to 18A, and that was that xD
Interesting dishwasher.. but I only wonder if that Smeg was made by Gorenje, or Gorenje took dishwasher from Smeg?
Post# 486846 , Reply# 12   1/6/2011 at 20:23 (4,848 days old) by jlbrazil (brazil)
BTW , here we don't pay to use , we use to pay lol
In my house we usually use 300 kWh per month , wich is about 85 euros or 120 dollars or 75 pounds per month.
Here energy is expensive :(
Post# 486897 , Reply# 13   1/7/2011 at 01:33 (4,848 days old) by dj-gabriele ()
@ jlbrazil
In Italy, 300kwh/month would be around 70€/month on a 6kwh contract but then again, sorry but I dind't consider Brazil as being "western" world
@ nrones
That SMEG dishwasher is a 100% SMEG design and product made in Guastalla, I had a friend working there before the moved to Bologna. They outsource the "new" plastic tub washing machine and the cheap refrigerators, they are made by either Gorenjie or Beko, some washing machine come from the BSH group.
We never had fuses till the early '60 and even then the preferred was a combination of magnetic and thermal switches and later they were accompanied to ground fault interrupters, colloquially called "salvavita" (life-savers).
@ gorenje
In fact you can't! The meter simply trips, they've done historically that thing to limit the fluctuations of the daily power curve and eliminate high inrush currents to residential buildings as they're difficult to predict. Anyway, thanks to this, the last black-out I remember was during the heat wave of 2003!
@ joe_in_philly
About our power meter: it is of the electronic kind, it shows you the instantaneous power consumption and the mean of the last months during the three daily price slots (morning, evening and night/weekend). If you happen to go over your instantaneous quota of energy, it displays a warning signal like "danger of disconnection, percentage XX of power exceeded" and if it stays the same, it will trip after a definite amount of time.
In Italy too the market is deregulated but the prices are quite the same, one can be lucky if he can save 7% in a year (in the case of Edison of Italy (part of Energie de France) to some 40% more!!!)
Post# 486936 , Reply# 14   1/7/2011 at 08:17 (4,847 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)
foraloysius's profile picture
Thank you very much for sharing these pictures. If my AEG hits the dust I will consider buying a Smeg dishwasher. I have seen a model that has about the same specifications as my AEG 6060.
Post# 487025 , Reply# 15   1/7/2011 at 13:47 (4,847 days old) by favorit ()
- The 3 KW-only thing - "3KW inhabitancy" electric company contract is the most common on Italy cause it cheaper (less taxes) than other ones.
Eg in my rental I too have 3 KW contract, but I have not the same fiscal agevolations, cause my inhabitancy is still at my parents.
you have to consider that ranges/hobs in Italy are 90% gas fueled and dishwashers became common only the last 15-20 years, so having just 3 kw available has never been a big issue
Actually delay timers on appliances are handy nowadays : when I have to run both W and DW (new thread coming soon!) in the meanwhile, I start the washer then i set one hour delay on the DW, so I'm sure it will start while the washer is rinsing and draws little power
@Foralouysius : that detergent + rinse aid dispenser is sooo familiar *LOL* . Guess both Smeg and Electrolux outsorce them from Eltek
@ DJGabriele : it's 100% SMEG .... but not made in Guastalla :-)) It' s made by Bonferraro, a company owned by Smeg based in Bonferraro di Sorgà, a village that's close to Mantova but in Verona province (link)
CLICK HERE TO GO TO favorit's LINK
Post# 487042 , Reply# 16   1/7/2011 at 14:34 (4,847 days old) by gorenje (Slovenia)
electric meter & indoor electric breaker box
This is my electric breker box that is installed above the main entrance in the flat and my electric meter. You can see a small arrow on the right side. It switches from the main rates to lower rates. (lower rates- from 10 PM to 6 AM and every Saturday and Sunday and Holidays)
Ingemar
Post# 487043 , Reply# 17   1/7/2011 at 14:36 (4,847 days old) by gorenje (Slovenia)
electric meter
electric meter 1
Post# 487044 , Reply# 18   1/7/2011 at 14:38 (4,847 days old) by gorenje (Slovenia)
electric meter
electric meter 2
Post# 487051 , Reply# 19   1/7/2011 at 14:49 (4,847 days old) by dj-gabriele ()
@Favorit
Cool to know it!
I guess I should call Michele and dress him down!
@ foraloysius
Oh, SMEG is my favourite brand, except this "standard" dishwashers, many others are works of art and perform brilliantly the same!
I especially like my oven, it has more functions than I could imagine (and I use them all!!!) plus the styling is so fantastic! And I love the build quality!
Post# 487056 , Reply# 20   1/7/2011 at 15:04 (4,847 days old) by dj-gabriele ()
@ Ingemar
That's an interesting concept, an electromechanical meter with two tariffs, is that synchronized with some kind of clock that operates the mechanism or does it get a signal on the power-line?
Post# 487081 , Reply# 21   1/7/2011 at 17:34 (4,847 days old) by gorenje (Slovenia)
electric meter
Hello Gabriele,
yes, as far as I know it's a kind of clock inside. Like a clock and an electronic calendar.
Ingemar
Post# 491441 , Reply# 22   1/25/2011 at 14:54 (4,829 days old) by ozzie908 (Lincoln UK)
2 rate meters
ozzie908's profile picture
Seeing that took me back a bit I remember back in the 70's I think it was the then electricity company called MEB thats midland electricity board, Were kean for people to use off peak tarrifs and they wanted those of us with elecric water heaters or heating to have these dual meters fitted. At the time they were good as the difference between day and night units was a lot I think then about 70% cheaper at night mostly we put our water heaters on a timer it was fine as long as you did not run out.:) Then along came washers and dryers which could be set to wait oh what a marvel they were! But after our gas oven dying aand only being able to get a electric to fit we had the dual rate removed as the saving was no longer worth the hassle of only being able to wash one load a night. Sorry for the ramble it all came flooding back to me lol
