Thread Number: 32303
You better eat your Wheaties...Hey, show me them cards!!! |
Post# 487115 , Reply# 1   1/7/2011 at 20:19 (4,829 days old) by supremewhirlpol ()   |   | |
He's going to auction off one of his laundromats pretty soon. These W-185's are being fixed. |
Post# 487116 , Reply# 2   1/7/2011 at 20:22 (4,829 days old) by supremewhirlpol ()   |   | |
These series1 W-73's are waiting to be sent to the scrap yard sadly. |
Post# 487118 , Reply# 3   1/7/2011 at 20:25 (4,829 days old) by supremewhirlpol ()   |   | |
Series 2 Wascomat w-123's waiting for scrap yard too. What a shame!! |
Post# 487119 , Reply# 4   1/7/2011 at 20:27 (4,829 days old) by supremewhirlpol ()   |   | |
Vintage Cissell dryers wait their turn too. |
Post# 487120 , Reply# 5   1/7/2011 at 20:30 (4,829 days old) by supremewhirlpol ()   |   | |
While up here I got to see my first Wascomat Gen6 in person! |
Post# 487123 , Reply# 7   1/7/2011 at 20:38 (4,829 days old) by supremewhirlpol ()   |   | |
The machine is FL184(Flex-O-Matic), looks like Jan,1987 manufacture date. Sounds about right. A 3 phase machine! |
Post# 487125 , Reply# 8   1/7/2011 at 20:40 (4,829 days old) by supremewhirlpol ()   |   | |
Looks to need a motor! Should not be hard to find one. |
Post# 487126 , Reply# 9   1/7/2011 at 20:44 (4,829 days old) by supremewhirlpol ()   |   | |
Top and front are SS! Machine works by Punch Cards |
Post# 487128 , Reply# 10   1/7/2011 at 20:45 (4,829 days old) by supremewhirlpol ()   |   | |
Machine can be operated manually too. Also has Temp gage. |
Post# 487129 , Reply# 11   1/7/2011 at 20:46 (4,829 days old) by supremewhirlpol ()   |   | |
Wonder what attaches here... |
Post# 487130 , Reply# 12   1/7/2011 at 20:49 (4,829 days old) by supremewhirlpol ()   |   | |
closer look, don't know what attaches here, but it is directly connected to the outer drum. |
Post# 487132 , Reply# 13   1/7/2011 at 20:52 (4,829 days old) by supremewhirlpol ()   |   | |
machine controls, looks interesting! |
Post# 487136 , Reply# 14   1/7/2011 at 20:55 (4,829 days old) by supremewhirlpol ()   |   | |
valves-> has hot and cold valves, and another inlet valve, not sure what the third one is for. |
Post# 487146 , Reply# 16   1/7/2011 at 21:20 (4,829 days old) by PeterH770 (Marietta, GA)   |   | |
You need 3 phase power for this baby.
The tube connector on the side is for chemical injection. Looks to be home rigged, as there should be ports on the back for chemical injection near the water valves. The 3 water valves are 1-hot, 2-cold and 3-hot to flush the detergent compartment. Most parts from a Gen 4 machine should work on this. Get an extra dump valve, Berkert (drain) solenoid, door lock assembly, and water valves. If the bearings are good, this should be an easy rebuild and you should get lots more years out of it. But you need 3 phase power... Is he also crushing the TD3030 dryers? He should. I have 13 of them that I want to crush myself with a smile on my face and a tap in my toes! |
Post# 487220 , Reply# 18   1/8/2011 at 04:56 (4,828 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 487254 , Reply# 19   1/8/2011 at 09:26 (4,828 days old) by supremewhirlpol ()   |   | |
Correct, this machine has a rigid base, no suspension. This machine MUST be bolted down. |
Post# 487256 , Reply# 20   1/8/2011 at 09:38 (4,828 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 487271 , Reply# 21   1/8/2011 at 11:05 (4,828 days old) by PeterH770 (Marietta, GA)   |   | |
The TD3030's are a complete nightmare. If it isn't the blower (E05 error) then it is the temp input thermistor (E17 error). And then there is the E14 gas valve errors. And the E15 errors when you forget to clean the secondary lint screens. Then there is the E99 general failure error. I have the first of the first of these. When they work, they are phenomenal, but look at them wrong and they will blow an error.
The extra valve is on the larger capacity machines to assist with the fill (it can be long with just the 2 valves) and to flush sticky, gooey additives into the machine and keep the dispenser box clean. This is the way it is on the Gen 5 and 6 machines; the Gen 4 setup may be different -- the center valve with the 3 solenoids are for the soapbox. Connect this to hot to keep the box a bit more fresh. I was looking at the drain. Is it the motorized one or the pancake/Berkert water solenoid one? Looks like the motorized one to me; I didn't see a Berkert solenoid up near the water valves. |
Post# 487337 , Reply# 24   1/8/2011 at 16:37 (4,828 days old) by supremewhirlpol ()   |   | |
Ah, Mac You mean these? |
Post# 487338 , Reply# 25   1/8/2011 at 16:40 (4,828 days old) by supremewhirlpol ()   |   | |
I was given several these as well as some blank ones. I don't know if these will cause my machine to function as it should, but it will be interesting as to what the machine will do with these cards. |
Post# 487339 , Reply# 26   1/8/2011 at 16:43 (4,828 days old) by supremewhirlpol ()   |   | |
I was told that the card is inserted all the way in the reader, and you turn the black knob to the left. |
Post# 487341 , Reply# 27   1/8/2011 at 16:45 (4,828 days old) by supremewhirlpol ()   |   | |
From how the reader is constructed, it looks like the card comes out of the reader during the course of the cycle. |
Post# 487342 , Reply# 28   1/8/2011 at 16:47 (4,828 days old) by supremewhirlpol ()   |   | |
He gave me an extra reader too. |
Post# 487343 , Reply# 29   1/8/2011 at 16:50 (4,828 days old) by supremewhirlpol ()   |   | |
It has several switches that hit against the bumps of the card, has a motor to advance card. |
Post# 487345 , Reply# 30   1/8/2011 at 16:52 (4,828 days old) by supremewhirlpol ()   |   | |
Looks like a terminal clip fits here over the terminals of the switches. |
Post# 487347 , Reply# 31   1/8/2011 at 16:55 (4,828 days old) by supremewhirlpol ()   |   | |
When you turn the knob to the left, this mechanism feeds the card. |
Post# 487361 , Reply# 32   1/8/2011 at 17:16 (4,828 days old) by supremewhirlpol ()   |   | |
I'm not sure what machine these cards go to, he gave me these as well. |
Post# 487363 , Reply# 33   1/8/2011 at 17:17 (4,828 days old) by supremewhirlpol ()   |   | |
Mac, What Brand and model was this 75LB. machine? |
Post# 487607 , Reply# 36   1/9/2011 at 16:34 (4,827 days old) by sudsman ()   |   | |
They are long gone.. Wascomat will help you with it I am sure. Or pretty sure you can still get a manual for it with out too much problem. |
Post# 487840 , Reply# 38   1/10/2011 at 03:43 (4,826 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Post# 487975 , Reply# 39   1/10/2011 at 15:41 (4,826 days old) by supremewhirlpol ()   |   | |
Oh a puncher! Thanks Laundress!! |
Post# 488279 , Reply# 40   1/11/2011 at 18:19 (4,825 days old) by supremewhirlpol ()   |   | |
Now working on locating an Elmo motor. Motor is 2 speeds, .45HP and 2HP, 3phase. |
Post# 489606 , Reply# 41   1/17/2011 at 16:28 (4,819 days old) by supremewhirlpol ()   |   | |
Just got back from another trip, only to bring home another machine and some parts! This is a tray to Wascomat Gen3 series(no timer). |
Post# 489608 , Reply# 42   1/17/2011 at 16:33 (4,819 days old) by supremewhirlpol ()   |   | |
Wascomat Gen3 tray with timer. |
Post# 489610 , Reply# 43   1/17/2011 at 16:34 (4,819 days old) by supremewhirlpol ()   |   | |
Pic of the timer. |
Post# 489612 , Reply# 44   1/17/2011 at 16:37 (4,819 days old) by supremewhirlpol ()   |   | |
Dump valve, fits Wascomat Gen 3 Series 2. Gen3 Series 1 machines have cast iron dump valves. |
Post# 489613 , Reply# 45   1/17/2011 at 16:38 (4,819 days old) by supremewhirlpol ()   |   | |
Wascomat Gen4 tray with timer |
Post# 489614 , Reply# 46   1/17/2011 at 16:40 (4,819 days old) by supremewhirlpol ()   |   | |
contactors, etc |
Post# 489615 , Reply# 47   1/17/2011 at 16:42 (4,819 days old) by supremewhirlpol ()   |   | |
Wascomat Flexomatic Gen 4 series Tray with complete card programmer. |
Post# 489616 , Reply# 48   1/17/2011 at 16:43 (4,819 days old) by supremewhirlpol ()   |   | |
Front buttons |
Post# 489617 , Reply# 49   1/17/2011 at 16:45 (4,819 days old) by supremewhirlpol ()   |   | |
Card programmer, even comes with a card. Sorry, no punch tool. |
Post# 489619 , Reply# 50   1/17/2011 at 16:46 (4,819 days old) by supremewhirlpol ()   |   | |
Post# 489622 , Reply# 51   1/17/2011 at 16:49 (4,819 days old) by supremewhirlpol ()   |   | |
Gen3 Series1 door handle, Gen3 series2, Gen4 handle assembly, Gen3 door lock mech, Gen 3 timer, Gen 3 emergency light assembly. |
