Thread Number: 32315
Maytag A608 convert to suds saver |
Post# 487302   1/8/2011 at 14:07 (4,853 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Folks---I'm thinking this out, bear with me, I'm trying to do a "poor man's" suds saver on an A608.
Drain hose----I added about 18 inch extension, and have one tub with a plug, and one tub draining out properly. I will have to manually move the drain hose immediately after the initial wash water drain, from the plugged tub to the drain tub, before the spray rinse starts. Then leave it there for the rest of the cycle. Water Level Switch-----I can install a 15 amp 120 volt switch to bypass the level sensor. When it's left off, power goes to the sensor switch but won't tell the timer to agitate until proper level is reached, normal operation. BUT, if I turn the switch ON, then immediately at start of wash cycle, the Maytag will think it's got full water level and immediately start agitating. Agitation mode means the pump works in reverse, sucking back in. Note----I have no intention of trying a darn thing with Perma-Press cycle, it goes thru so many partial drains and refills, it's nuts. So, to start a load from scratch, I plug the tub with the sole drain hose in it, start a normal cycle. When it exhausts water after wash, I move the hose over to the open draining tub and let the machine cycle all the way through to finish. Then, for the second load, I leave the washer empty of clothes, switch the water level bypass switch to ON position, put the hose into the plugged tub full of water, and start normal agitation. This will syphon the suds back into the washer. When the suds tub is almopst empty, I stop the machine. Turn the level bypass to OFF so it operates normally, push whatever hot/warm/cold button I want and high-medium water level desired, put clothes in, start normal cycle again. It will sense if it got back a full tubful or not, fill whatever small amount needed, and run the cycle (with me moving hose and plugs depending on my desires to use a third time or let everythong go down the drain. Holes in my theory: I better keep a close eye on which tub gets the hose and when, have to remember to turn the bypass switch OFF as soon as syphoning is done or I'll end up rinsing with no water at all, etc. So, I know it's both a cheap way to do things and not in the least automatic, but I watch every load of clothes thru the 4 different machines I own anyhows, so no big deal. I'm used to TwinTubs and wringers, so this is no big deal for me. Can anyone suggest simple cheap alternatives or warnings? O r do I have all the bases covered? Additionally, I keep my eyes on estate sales and Craigslist for a REAL suds saver, but this Maytag is 31 years old already, cost $22.50, I figure I can play with it a bit. Thanks Mark |
Post# 487315 , Reply# 2   1/8/2011 at 15:25 (4,853 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 487318 , Reply# 3   1/8/2011 at 15:30 (4,853 days old) by goatfarmer (South Bend, home of Champions)   |   | |
Post# 487533 , Reply# 5   1/9/2011 at 12:31 (4,852 days old) by akronman (Akron/Cleveland Ohio)   |   | |
All of you are correct, there's more than one way to save suds with so many machines. But I also just wanted to start "revising" an old machine, make it do what I wanted it to, and it was a 20 minute job and $4.97 for the switch. And it works! Anyone wanting specifics on the wiring, please holler back, my first try didn't work.
Thanks for help and advice-- Mark |
