Thread Number: 32428
Kitchen Aid Superba Monterey door springs |
Post# 489201 , Reply# 1   1/15/2011 at 20:58 (4,842 days old) by rp2813 (Sannazay)   |   | |
OK, you have the tops of the springs attached to the hinge piece on each side. Directly behind the travel path of the hinge there is a vertical support member on each side. At the bottom of each of those vertical pieces is an unpainted metal strap (it's unpainted on my machine) held in by a single screw. Near the front of that unpainted strap is a hook for the spring. It's very close to where the adjusting feet screw through. It may be easier to feel it than see it.
The springs should be silent. Make sure nothing is binding anywhere. |
Post# 489206 , Reply# 2   1/15/2011 at 21:12 (4,842 days old) by stevet (West Melbourne, FL)   |   | |
Raplh, great minds think alike..we are reading these posts at the same time. Here is a quick pic of the springs to help Steve find his way! Hope it works for you! |
Post# 489218 , Reply# 3   1/15/2011 at 21:51 (4,842 days old) by rp2813 (Sannazay)   |   | |
