Thread Number: 32495
WP detergent dispenser door |
Post# 490091   1/19/2011 at 10:48 (4,838 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
does anyone have some advice...have a WP powerclean with the normal WP dispenser on the RH side of the door with the single flap door, held by the catch against a small spring. Normally the door (with the gasket) is open, you close it against the spring and when it opens it flings open.
We closed the door on a too-thick detergent tablet and it sprung the spring (didn't break the door or the pin). the door now hangs there limply and doesn't let the tablet/pack fall into the sump any advice on how you get the spring re-sprung? it's difficult because we're both big guys and there is no clearance on the RH side of the d/w to get close (effectively you're working at arms length) |
Post# 490104 , Reply# 1   1/19/2011 at 11:35 (4,838 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 490114 , Reply# 2   1/19/2011 at 12:20 (4,838 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
Post# 490170 , Reply# 3   1/19/2011 at 15:35 (4,838 days old) by joe_in_philly (Philadelphia, PA, USA)   |   | |
My mother's dishwasher had the same problem. The spring was not placed properly, so it did not spring the door open when the catch moved. I was able to take it apart and then put it back together with the spring seated correctly. It took a some patience to as you have to properly place the two ends of the spring in the right spot and then wind it back to create the tension before snapping it in place. I can't explain it easily, but just keep in mind the spring needs to be wound so that it creates enough tension to keep the door open and hopefully you can figure it out.
Hopefully someone can explain it better! |
Post# 490312 , Reply# 5   1/20/2011 at 07:32 (4,837 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
It is not necessary to take the door apart or even turn off the power. It is just necessary to re-tension the spring and hook it back over the little plastic tab that holds it tensioned. It is a little hard to describe how to do this but it only takes me 45 seconds and you only need a small flat blade screwdriver or even a nail file to do this.
Post# 490313 , Reply# 6   1/20/2011 at 07:42 (4,837 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 490367 , Reply# 7   1/20/2011 at 12:52 (4,837 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
