Thread Number: 32525
kitchenaid 21 pump access? |
Post# 490517 , Reply# 3   1/21/2011 at 07:30 (4,843 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 490656 , Reply# 9   1/21/2011 at 19:59 (4,842 days old) by Combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The check valve is in the drain line about one foot from where the drain hose connects to the bakelite pump housing. It is light blue plastic you should be able to blow through it only in the direction the water drains. If you can blow through it both ways you need to replace the rubber diaphragm inside otherwise the dishes won't wash in the top rack of the machine.
Post# 490658 , Reply# 10   1/21/2011 at 20:15 (4,842 days old) by pdub (Portland, Oregon)   |   | |
Post# 490662 , Reply# 11   1/21/2011 at 20:52 (4,842 days old) by rp2813 (Sannazay)   |   | |
It's my understanding that there's a GE part that can be used in place of the NLA KA check valve.
It's also my understanding that John (combo 52) can advise on the GE part number.
The 2nd ISE Classic Supreme I found came with a good check valve so I haven't had to pursue the GE alternative.
Steve, if you can hear an "urping" sound from the end of the drain hose while the machine is washing, that's an indicator of a bad check valve.
Ralph |
Post# 490783 , Reply# 15   1/22/2011 at 14:41 (4,841 days old) by wigwag (San Diego)   |   | |
Hi Steve, Ya I figured I went deep enough. I'll give a full progress report with pictures as soon as the days over and we get the kids to bed. Steven |
Post# 490792 , Reply# 16   1/22/2011 at 15:40 (4,841 days old) by pdub (Portland, Oregon)   |   | |
