Thread Number: 32681
I Think I Ruined My Washing Machine.... |
Post# 492520 , Reply# 1   1/29/2011 at 21:55 (4,833 days old) by cfz2882 (Belle Fourche,SD)   |   | |
never had that problem,but i'd try to run it deliberatly overdosed with sudsy detergent several times-could try dishwashing detergent in it and see if that gets the diesel odor out.(i see cascade was mentioned) |
Post# 492521 , Reply# 2   1/29/2011 at 21:58 (4,833 days old) by ronhic (Canberra, Australia)   |   | |
My brother in law is a mechanic who served his apprenticeship rebuilding differentials. Trust me when I tell you that, from an oil point of view, nothing smells worse....
Not knowing the effect it would have on my machine, I had offered to run a couple of loads through for my sister when hers was on the blink...
WELL...oh my stars! What a STINK was left in my machine.......
Remember how greasy diesel is.....I would suggest doing the following:
- add a double dose of dishwasher detergent to the drawer - choose the hottest, longest cycle - let it run...
Dishwasher detergent is more alkyline than normal clothes detergent so should help strip the oil from the outer drum...
Then immediately after:
- use the same cycle - add some old towels - use a powdered, normal detergent - no softener
....this should help restore the protective elements that the dishwasher detergent will strip away as well as deodourise the machine... |
Post# 492543 , Reply# 3   1/29/2011 at 23:14 (4,833 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
I remember when I worked on a 100' Motor Yacht, when seas were rough, I used to hang in the Engine Room with the Engineer while underway.
I would help him with changing Sea Strainers and just give a hand with his chores when the seas were too crazy to cook. We Used White Vinegar in the Laundry and also to wash your hair to get the Diesel smell out. So Try a Couple of Cups in the Cylinder before you start the machine. I Hope this Works. Eddie |
Post# 492597 , Reply# 5   1/30/2011 at 10:35 (4,833 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 492601 , Reply# 6   1/30/2011 at 11:14 (4,833 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 492632 , Reply# 7   1/30/2011 at 14:02 (4,833 days old) by whirlcool (Just North Of Houston, Texas)   |   | |
Your right about the degreaser. I'd run a hot load with a tsp of Dawn in the machine. I'd turn it off mid cycle and let it sit for a couple of hours and rinse several times. |
Post# 492637 , Reply# 8   1/30/2011 at 14:12 (4,833 days old) by laundromat (Hilo, Hawaii)   |   | |
Go and get some "Spray-9" cleaner/disinfectant and run the washer on the hottest water/longest wash cycle. Spray-9 will not only remove the residue but take the smell away too.The best place to find it is most auto supply stores because it does great work in detailing car interiors as well as wheels and tires.
Post# 492642 , Reply# 9   1/30/2011 at 14:21 (4,833 days old) by yogitunes (New Jersey)   |   | |
Once you have mechanics in the family, you quickly learn......
go to Walmart, or PepBoys, AutoZone, or most auto parts stores buy Purple Cleaner/Degreaser....about 5.00 to 8.00 a gallon Hot water and a few cups of this will erase most of everything in the machine, using a cup with any greasy load will eliminate this in the first place....it will suds alot...... also future loads using Lestoil will also help I take my brothers greasy work clothes out and lay them in the drive way, load up the pump sprayer with this stuff, and pretreat both sides, Hot water wash, Tide powder with bleach, and the longest cycle......perfect results everytime...this also kills weeds/grass in the driveway...win/win Purple Cleaner is very STRONG.....one brother pretreated his clothes while laying them over top of my Kenmore Limited's, and it wiped all the lettering off the control panels.........many nasty words later, I got a new set, and did his clothes myself.... you may want to take an unknown load like this to a laundromat next time...just a thought |
Post# 492647 , Reply# 10   1/30/2011 at 14:36 (4,833 days old) by laundromat (Hilo, Hawaii)   |   | |
Spray-9 has been around since th 60's and hasn't changed its formula since.I use it on everything except the lettering on the controls i.e. burner knobs that have the decals instead of indented heat settings and temperatures and get fantastic results.Its aroma is mild and it really gets the grease,grime,germs,mold,mildew and embedded dirt and scum off of mostly everything.I recently used it on a Ford F350 with a bubble top that was so full of mold and mildew that it looked like it had a real bad paint job in green.I sprayed the Spray 9 on, let it penetrate about 15 minutes and used a scrubber to help release the particles.The bubble top went from a forest green to snow white.I also sprayed the bed that was also full of filth and smelled like s**t.It too cleaned up remarkably well with very little effort on my part.Just had a scrubby pad,elbow grease and a pressure washer.
Post# 492727 , Reply# 12   1/30/2011 at 21:32 (4,832 days old) by ronhic (Canberra, Australia)   |   | |
Post# 492874 , Reply# 13   1/31/2011 at 18:14 (4,832 days old) by robliverpool (england Liverpool)   |   | |
I know this is going to sound daft but i done a similair thing about 8 years back and a whole tube of toothpaste NOT THE GEL TYPE has to be paste, works. 60c wash nothing in the drum ie clothes or detergent just use full tube of good toothpast like colgate, also very good for getting permanent marker from paint work and leather
Just squirt the full tube into the drum not the drawer and let the machine do the full cycle (",) |
Post# 492962 , Reply# 14   2/1/2011 at 00:40 (4,831 days old) by ronhic (Canberra, Australia)   |   | |
Post# 493022 , Reply# 17   2/1/2011 at 11:47 (4,831 days old) by logixx (Germany)   |   | |
3beltwesty is certainly right. Look at the cleaning cycles most modern US front loaders have: they run a low-speed spin with hot water in the tub to clean out the entire drum. If your Bosch doesn't have this, you can do the following. Run the hottest cycle with some cleaning agent - maybe add an extra gallon of water through the dispenser. However, do not let the machine drain the hot suds at the end of the main wash. Let them drain into a bucket or similar. Turn the cycle knob to Drain/Spin and put the drain hose down the dispenser. When the machine is up to speed, add the cleaning solution via the detergent dispenser. This way, the spin cycle will help to scrub the entire drum assembly. If the cleaner you use is high sudsing, use a low spin speed. After the spin cycle is done, reset the washer to another Drain/Spin cycle and, with the drain hose removed from the dispenser, pour another bucket of water into the machine while spinning. This will quickly flush everything out.
I do this on my grandma's Miele all the time as it doesn't have a self clean cycle. The link below will show you the kind of action that happens inside the tub - this was filmed with our top loader running a 1000 rpm spin with some water in the tub. Alex CLICK HERE TO GO TO logixx's LINK |
Post# 493068 , Reply# 18   2/1/2011 at 14:35 (4,831 days old) by 3beltwesty ()   |   | |
There is the old Southern thing of using Coke Cola to remove the smell too. Baking soda is ancient too. Simple Green, Eye of Newt too |
Post# 493201 , Reply# 19   2/1/2011 at 21:25 (4,830 days old) by takacedon (Salt Lake City)   |   | |
About 30 cycles later and 3 washes of rags, I think we've gotten it. The good thing is none of the clothing is smelling of diesel. Thanks everyone! |
Post# 493258 , Reply# 20   2/2/2011 at 00:15 (4,830 days old) by ronhic (Canberra, Australia)   |   | |
Post# 493337 , Reply# 22   2/2/2011 at 10:50 (4,830 days old) by fordtech ()   |   | |
Ive used the Coca Cola trick before on 90 weight embedded into coveralls.. took a few loads but it did take out the bulk of it. |
Post# 493360 , Reply# 23   2/2/2011 at 12:40 (4,830 days old) by mtn1584 (USA)   |   | |
PINE SOL, PINE SOL, AND MORE PINE SOL, THEN RINSE RINSE RINSE TRY IT..... Mike |
Post# 493972 , Reply# 24   2/4/2011 at 15:22 (4,828 days old) by robliverpool (england Liverpool)   |   | |
Yes really toothpaste does work, dont ask me how but it does, found out by accident when i washed the car mats that had oil on them and the machine stunk of oil fumes and all i had was toothpaste and i thought, what the heck, sunday night, no powder left and used a full tube of colgate and it worked first time.
