Thread Number: 32697
A108 - wouldn't spin - did I make the tub too tight? |
Post# 492685 , Reply# 1   1/30/2011 at 17:13 (4,833 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Post# 492688 , Reply# 2   1/30/2011 at 17:24 (4,833 days old) by beekeyknee (Columbia, MO)   |   | |
Post# 492690 , Reply# 3   1/30/2011 at 17:38 (4,833 days old) by Lucy ()   |   | |
You decide. |
Post# 492750 , Reply# 5   1/30/2011 at 23:39 (4,833 days old) by qsd-dan (West)   |   | |
The belt seemed a little glazed looking to me, and it is not an original Maytag belt - it was the closest John Deere one we could find, but it has worked fine for 10 years.
Purchase genuine Maytag belts ONLY! The transmission belt has a cloth like covering and is designed to slip for the spin cycle. Standard belts are designed to aggressively grip. I'm really surprised the John Deer belt has lasted 10 years. A standard belt usually breaks...immediately! The pump belt generally slips very little, if at all, so I can see that one lasting for a while. but then it wouldn't spin....The tub is hard to turn, but as I recall it was also hard to turn when I was turning it during disassembly. Most common error for first timers is that the tub cover is pushed too far down during the re-installation process, contacting and jamming the inner tub. Loosen the metal seal band and lift the cover up 1/4-1/2 inch or so all around. Does the inner tub turn easier now? |
Post# 492785 , Reply# 6   1/31/2011 at 08:08 (4,833 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
