Thread Number: 32753
anyone have Kitchenaid Imperial Selectra service literature? |
Post# 493637 , Reply# 1   2/3/2011 at 07:53 (4,802 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 493682 , Reply# 2   2/3/2011 at 12:46 (4,801 days old) by rp2813 (Sannazay)   |   | |
Yes, both of my machines (not Selectras) have it wrapped in plastic behind the main panel. I thought Steve meant there were special instructions for the Selectra's controls behind the console panel.
You have to remove the entire panel, not just the insert(s) on the front of it. That means that the four screws I told you not to confuse with the two that hold the control panel in place are the ones that you need to undo. It might be necessary to remove at least one of the side trim strips when you replace the panel, but cross that bridge when you get there.
If you open the door flat to accomplish this, put something under it so the panel assembly doesn't drop to the floor. It also requires a bit of dexterity to put the panel assembly back into place, but it can be done without the help of another person.
Ralph
