Thread Number: 32759
CU washer-dryer reviews |
Post# 493686 , Reply# 2   2/3/2011 at 13:22 (4,822 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
I would like to try a Front Loader for my busy Summer schedule. I have 3 Maytags TL (886,606,and 806) so I'm fine with having a back up machine (Plus the Unimatic, the 61 Whirlpool and a Speed Queen) And also the Owner's Shredmore.
During the summer as a Chef, I go through alot of Shorts, Pants, T-shirts and Chef Coats. The owners of the house that I take care of are also here. And we are on a Septic System. So on My Dime, I was thinking in the summer when the Water Consumption is High (Laundry, Showers etc) I am thinking about a Front Load. But, I really don't want to spend more than $700-$800. I am looking at the Whirlpool Duet Model WFW 9150 WW. It retails out at $649.00 and is 4.0 cu capacity. Do you think this is a reliable good cleaning machine ? I know that most of the New Machines are a Crap Shoot as far as Dependability and Reliability, but what do you think is the best Bang for the Buck in my price range ? Thanks, Eddie |
Post# 493754 , Reply# 3   2/3/2011 at 19:33 (4,822 days old) by appnut (TX)   |   | |
Post# 493767 , Reply# 4   2/3/2011 at 19:55 (4,822 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 493784 , Reply# 5   2/3/2011 at 20:31 (4,822 days old) by appnut (TX)   |   | |
Of the two, the Maytag can eek out a head a bit, even though they are both essentially the same machine with slightly different features. From what I've understood from a couple of people here and on other laundry forumes, Maytag is what KitchenAid laundry products used to be and probably would have been if Maytag hadn't had it's brand name thrown in the mix. Some of the components are supposedly beefed up over the WP cousin--door hinges, sturdier drive belt, ... Neitehr one has a supplemental heater. the Maytag MAY, but I question that. The Maytag has a PowerWash cycle that's very long and does use hot water, but hot water isn't going to stay hot for an hour or 1.5 hour wash phase. It has a "stain tret" option which changes any preset wash temp to warm to deal with protein stains. It adds time, different tumbling patterns. Who nkows, maybe this is how laundry will be done if, what Malcolm has been told by Speed Queen, all washers with supplemental heaters will be going away in 2-3 years for energy Star purposes and and detergents designed to work with cooler temps. Of the two, I'd opt. for the Maytag if I had to choose. I can tell you I definitely lke it's beheamouth big brother Mr. Steam engine and will rpobably spring for that when my Fridgemore gives up the ghost. It's a different approach to doing laundry, but I still personally am of the opinion front loaders wash much better than top loaders. |
Post# 493786 , Reply# 6   2/3/2011 at 20:39 (4,822 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 493817 , Reply# 7   2/3/2011 at 21:49 (4,822 days old) by appnut (TX)   |   | |
Post# 493818 , Reply# 8   2/3/2011 at 21:56 (4,822 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Consumer Report came today. I just finished reading the report. This Maytag has almost the same rating as some of the $1400.00 machines. The only "Good" rating on it was is the Noise Level. Everything else is either Excellent or Very Good. Sears has it for $569.00I think I'm going to look at it tomorrow.
What's your opinion on the InteliFill ? |
Post# 493821 , Reply# 9   2/3/2011 at 22:27 (4,822 days old) by appnut (TX)   |   | |
Post# 493826 , Reply# 10   2/3/2011 at 22:35 (4,822 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 493837 , Reply# 11   2/4/2011 at 00:22 (4,822 days old) by rp2813 (Sannazay)   |   | |
Eddie, the Duet we bought a few years back had a "Whitest Whites" cycle. Although it did have an on-board heater, it was only used on the "Sanitary" cycle. It seemed that the only thing that the "Whitest Whites" cycle instructions included was the advice to add bleach. Other than that, it was just another cycle with no on-board heater involvement.
Ralph |
Post# 493853 , Reply# 12   2/4/2011 at 03:14 (4,821 days old) by DADoES (TX, U.S. of A.)   |   | |
Post# 493860 , Reply# 13   2/4/2011 at 05:44 (4,821 days old) by appnut (TX)   |   | |
Ralph, actually cycle schematic called for the supplemental heater to come on for the Whitest Whites as well as the heavy Duty Cycle--that one4 gradually heated the wateer frmo warm to hot. so there were 3 cycles the heater was used for, on the white the hot water temp had quite a range to go down before the heater kicked in thoutgh. Probably your hot waterr heater temp was set high enough where it didn't end up needing the heter to come back on. |
Post# 493886 , Reply# 14   2/4/2011 at 08:01 (4,821 days old) by Iheartmaytag (Wichita, Kansas)   |   | |
