Thread Number: 32791
The washer's home but its' not a whirlpool duet |
Post# 494144   2/5/2011 at 14:28 (4,820 days old) by maypool ()   |   | |
Hey guys it's a G.E. high efficiency washer tell me your views on these washers what do you guys think. |
Post# 494146 , Reply# 1   2/5/2011 at 14:30 (4,820 days old) by maypool ()   |   | |
here's up close shot picture taken with my camera phone |
Post# 495488 , Reply# 3   2/10/2011 at 13:22 (4,815 days old) by 3beltwesty ()   |   | |
It might be a rebranded LG or Samsung |
Post# 495494 , Reply# 4   2/10/2011 at 13:41 (4,815 days old) by laundromat (Hilo, Hawaii)   |   | |
The GE front loaders are made in China by Little Darling. Not Samsung and absolutely not LG.The beginner models are made by Frigidaire.They (GE) just introduced a new set of front loaders that are a bit upscale from their previous line. I have had numerous customers who bought them from HD when I worked there and they have had no issues at all.Just be sure to:
1. Check all pockets in slacks,shorts,shirts and dresses for change or anything that Could get stuck in the pump and cause a service call 2. Use only HE or lo sudsing detergents. 3. When washing bedspreads,lay the spread on the floor and grab it from the center. Feed it in like you would a pin or screw into the opening. This helps to eliminate the load going off balance. It also helps to keep a more uniform wash and rinse. 4. Check the "button catcher" which is the small door at the right side bottom. Put a bowl underneath to catch any loose water and remove the small cylinder by turning it counter clockwise. Inside, there may be a small amount of lint and anything that may have been in pockets or in the pile picked up accidentally or unknowingly.This really helps to eliminate any service calls. 5. LEAVE THE DOOR WIDE OPEN AFTER YOU'RE FINISHED DOING WASH FOR THE DAY!!! Most people who are not as familiar with the front loaders have a bad habit of closing the washer after use and wonder why,after waiting a full week to do the next load(s)with the door tightly shut,why there is this bad smell inside. Hello!! Anybody home??!! If you had a vacation home and were closing it down for the season,would you leave the refrigerator turned off with the doors closed? Same principle. When there is humidity inside an area that is air tight and closed, it has nowhere to escape or evaporate.In order to remove or allow the excess humidity to evaporate,you must leave the washer door open.It not only helps keep the humidity from stagnating but also keeps the washer interior smelling fresh and clean. |
Post# 495945 , Reply# 5   2/12/2011 at 12:19 (4,813 days old) by maypool ()   |   | |
the machine is so quiet and it runs fine thanks so much for the info. |
Post# 495947 , Reply# 6   2/12/2011 at 12:27 (4,813 days old) by jamman_98 (Columbia, SC)   |   | |
Post# 496280 , Reply# 7   2/13/2011 at 17:58 (4,812 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 496281 , Reply# 8   2/13/2011 at 18:04 (4,812 days old) by nmassman44 (Brooksville Florida)   |   | |
Post# 496778 , Reply# 9   2/16/2011 at 03:40 (4,810 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 503652 , Reply# 10   3/12/2011 at 22:05 (4,785 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 503883 , Reply# 11   3/13/2011 at 18:06 (4,784 days old) by Frigilux (The Minnesota Prairie)   |   | |
