Thread Number: 33060
Maytag A606 leak. Metal band clamps/screws rusted. |
Post# 497735 , Reply# 1   2/19/2011 at 17:53 (4,807 days old) by bendixmark (Winchester Mass)   |   | |
Cut the screw in half with a hacksaw then pry out the little band that is holding the square nut in place.They sell relacement screws and nuts through maytag or a hardware store may even have that,I did it that way years ago. |
Post# 497756 , Reply# 2   2/19/2011 at 19:07 (4,807 days old) by qsd-dan (West)   |   | |
Post# 497791 , Reply# 3   2/19/2011 at 21:31 (4,807 days old) by autowasherfreak ()   |   | |
I had to replace the clamp on my 606, I bought a used one from a local Maytag dealer, for $20.00.
Post# 498420 , Reply# 5   2/21/2011 at 21:31 (4,805 days old) by akronman (Akron/Cleveland Ohio)   |   | |
Hey----check the thin hose from base of exterior tub up to the water level sensor. It is skinny, easy to dis-locate, and needs to be properly installed to stop the water at the right level.
Rear right corner of interior of machine, lower right rear of outside of tub, then runs up into the controls, fits on the back of the water level switch. Try that first, easy to knock off when working on that tub ring. Check it at both ends for secure fit. If there's any hole or leak, then the air pressure from the filling tub, pushing air up inside that little flexible tube, will leak out and the level sensor switch will keep running forever. |
Post# 498472 , Reply# 6   2/22/2011 at 07:45 (4,804 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Any time any washer won't stop filling unplug the machine first and if the water continues to enter the machine you have a bad fill valve plain & simple. Replace the inlet valve assembly with a new one if available, don't even think of disassembling and cleaning-rebuilding unless a new one is not available for your washer. If the water does stop coming in then start looking at the water level switch and the little hose attached to it that runs down and attaches to the outer tub. A lot of MTs get a gunky buildup in the larger part of this hose where it transitions down in size that can eventually clog and cause the washer to over fill and flood. This clogging usually results from washing in too cold water with too little detergent and possibly too much fabric softener.
The band clamp and rubber gasket around the top of the tub usually doesn't leak unless it has been disturbed. But if you need to reseal this you usually don't need a new rubber gasket unless yours is hard & cracked, if it is not it can be reinstalled with some silicone sealant if necessary. |
Post# 499144 , Reply# 8   2/25/2011 at 01:02 (4,802 days old) by qsd-dan (West)   |   | |
Don't make that taped hose fix permanent or it'll bite you in the rear end down the road by flooding your house. New ones are still available. Here's one on Ebay.
CLICK HERE TO GO TO qsd-dan's LINK on eBay |
Post# 500120 , Reply# 10   2/28/2011 at 17:02 (4,798 days old) by Volvoguy87 (Cincinnati, OH)   |   | |
Are you referring to the rubber seal between the outer tub top and the outer tub bottom? This triangular seal is still available, and it's pretty inexpensive too. I just replaced one.
To replace: remove the tub clamp by loosening the 2 screws. Pull the tub top straight up, the rubber seal may stick a bit, so be careful in how you persuade the tub top out. Note where the tub seal is located on the tub top. Remove the rubber seal and clean up the tubs to remove mineral deposits and rust. Put the new seal in the same spot as the old one on the tub top and lower it back into place inside the outer tub bottom. The rubber seal determines how far down it will go. Make sure the rubber triangular seal is not twisted. Also, make sure the inner tub will not hit the tub top, pay close attention to where the water inlet is located (about 10:00). Tighten the tub clamp screws TIGHT! The new screws from Maytag have a hex head instead of a slotted one, I like this better. good luck, Dave CLICK HERE TO GO TO Volvoguy87's LINK |
