Thread Number: 33109
Kitchenaid Superba by Hobart -Leaking Pump? |
Post# 498534 , Reply# 1   2/22/2011 at 12:52 (4,805 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 498656 , Reply# 2   2/22/2011 at 22:05 (4,804 days old) by rollermatic (cincinnati)   |   | |
Post# 498662 , Reply# 3   2/22/2011 at 23:12 (4,804 days old) by appnut (TX)   |   | |
Post# 498802 , Reply# 5   2/23/2011 at 16:10 (4,804 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 498820 , Reply# 6   2/23/2011 at 17:09 (4,804 days old) by marksman ()   |   | |
Tried???? That doesn't sound good! What happened? Hopefully someone can point me to that thread. |
Post# 498849 , Reply# 7   2/23/2011 at 19:10 (4,803 days old) by rollermatic (cincinnati)   |   | |
which is called the wash arm support you see the top impeller. you removed it too you said. underneath that is a plastic peice that has 4 screws holding it in. you removed those screws you said. this peice will lift out. underneath it is the bottom impeller and seal that you are replacing.
make sure no water is in pump that will leak down into motor when you remove bottom impeller and seal. i usually disconnect drain hose off pump and let all water out into a rag or cup so motor bearing area will stay dry. you will also have an o ring between bottom and top impeller on shaft and several spacers that will go back in with new assembly. that's a start at least. |
Post# 498860 , Reply# 9   2/23/2011 at 19:45 (4,803 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 501438 , Reply# 10   3/4/2011 at 23:58 (4,794 days old) by bpetersxx (laf in on the banks of the Wabash River)   |   | |
