Thread Number: 33110
GE / Kenmore |
Post# 498538   2/22/2011 at 13:02 (4,808 days old) by peteski50 (New York)   |   | |
Post# 498539 , Reply# 1   2/22/2011 at 13:03 (4,808 days old) by peteski50 (New York)   |   | |
Post# 498631 , Reply# 2   2/22/2011 at 20:38 (4,808 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 498645 , Reply# 3   2/22/2011 at 21:07 (4,808 days old) by cfz2882 (Belle Fourche,SD)   |   | |
interesting that they were still using that nasty shaded pole pump motor -noisy and uses about twice the power of a split phase of same HP rating... |
Post# 498674 , Reply# 4   2/23/2011 at 02:03 (4,808 days old) by cyclemonitor ()   |   | |
I had one of these...and it was very NOISY
Peter you beat me to this one, I was going to post this the same day you did. LOL!
Post# 498774 , Reply# 6   2/23/2011 at 14:29 (4,807 days old) by jamiel (Detroit, Michigan and Palm Springs, CA)   |   | |
Post# 498791 , Reply# 7   2/23/2011 at 15:41 (4,807 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 498956 , Reply# 9   2/24/2011 at 07:12 (4,807 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
You hit the nail on the head ctz2882 these motors used over 4 times the power of the motor that replaces it and the large cooling fan contributed heavily to the noise level, let along when the fan would come loose on the motor shaft. GE had trouble with loose fans all through the 1990s. The other thing I hated about these motors is that when they were under load the motor speed would vary so the machine would sound like it was straining while it was washing.
3bwesty on these machines the motor actually did use more power than the heater, the model tag for these machines lists the heater draw @ 5 AMPS and the motor @ 5.5 AMPS. I always thought they should have wrapped copper water tubing around the motor and used all the waste heat to heat the wash water. You could really feel the heat generated by GE DWs when you had the lower panels off when you were lying on the floor working on them. |
Post# 499575 , Reply# 10   2/26/2011 at 21:18 (4,804 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Peter thanks for the scans...
I had a good time with these GE dishwasehers i just like to here the tower hit the top of the console with that long sweeping action GE is famous for in there tower sprayarm systems. My friend has time share at the beach in Ocean city NJ. here are the pics of the Dishwasher we use when down there. Sorry small Pics. This post was last edited 02/26/2011 at 21:54 |
Post# 499582 , Reply# 11   2/26/2011 at 21:25 (4,804 days old) by aldspinboy (Philadelphia, Pa)   |   | |
It cleans very well and this model that been branded Kenmore was pretty quite compared to other models.
I beleave this was the last of them ,this had the boosted prewash and water heat cycle. This post was last edited 02/26/2011 at 21:52 |
Post# 499601 , Reply# 12   2/26/2011 at 21:51 (4,804 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 499602 , Reply# 13   2/26/2011 at 21:53 (4,804 days old) by peteski50 (New York)   |   | |
