Thread Number: 33168
25 year old KDI21A |
Post# 499511 , Reply# 2   2/26/2011 at 18:42 (4,779 days old) by rp2813 (Sannazay)   |   | |
I don't know if the 21 series still used a Hobart pump. If so, you can probably order one from Hobart.
Steve, the Hobart expert here will hopefully provide an informational post.
Be sure there's nothing stuck in the filter assembly under the wash arm. The arm lifts off as do the filter components below it. |
Post# 499530 , Reply# 3   2/26/2011 at 20:10 (4,779 days old) by kkwolfe ()   |   | |
I have cleaned out the filter assembly under the wash arm. There didn't seem to be any problem there. |
Post# 499532 , Reply# 4   2/26/2011 at 20:13 (4,779 days old) by neptunebob (Pittsburgh, PA)   |   | |
Look underneath and see if there is a leak around the driveshaft. If there is, do not run it until you have it repaired.
I tried to save an older model KA but it turns out the motor was already shot because the leak was allowed to happen.
I think the parts should be still available. the 21 is about the furthest that Sears Parts Direct will go.
Another thing, try to remove all of the wash arm, filters, as far down as you can go, there could be a foreign object, broken glass (be careful) that could be causing the noise.
Post# 499581 , Reply# 5   2/26/2011 at 21:22 (4,779 days old) by cfz2882 (Belle Fourche,SD)   |   | |
older hobart motors had replacable ball bearings so if the seal has leaked and damaged the bearings,the bearings can be replaced after the seal is repaired(if the motor is the ball bearing version) |
Post# 499609 , Reply# 6   2/26/2011 at 22:11 (4,779 days old) by rp2813 (Sannazay)   |   | |
I don't think this machine is old enough to have replaceable bearings.
I'm also not sure if it can be assumed that since the ID tag indicates the machine was made by Hobart, if the pump was still a Hobart product or if Emerson was making them by the time the 21 series was being produced.
Steve will know for sure, and should be able to provide a source for replacement parts. |
Post# 500087 , Reply# 9   2/28/2011 at 13:57 (4,777 days old) by kkwolfe ()   |   | |
Sears Parts Direct no longer has pumps for this machine. They carry a few miscellaneous parts, but nothing major. |
Post# 500100 , Reply# 11   2/28/2011 at 15:24 (4,777 days old) by kkwolfe ()   |   | |
Post# 501955 , Reply# 14   3/6/2011 at 18:43 (4,771 days old) by retromania (Anderson, South Carolina)   |   | |
Those older KitchenAids we such nice machines! |
Post# 501961 , Reply# 15   3/6/2011 at 19:06 (4,771 days old) by rp2813 (Sannazay)   |   | |
Post# 502173 , Reply# 18   3/7/2011 at 12:49 (4,770 days old) by rp2813 (Sannazay)   |   | |
Lemishine contains citric acid. It's main purpose is to get your glassware sparkling, but will also help to clean up your machine's interior and components in the process. I think it has instructions for dishwasher cleaning on the label. It comes in a plastic container that resembles the type Comet cleanser comes in. I think I'd just fill both detergent cups with it and let 'er rip.
White vinegar also works, but it smells bad. |
