Thread Number: 33185
Time to release some tension! |
Post# 499555 , Reply# 1   2/26/2011 at 20:56 (4,779 days old) by supremewhirlpol ()   |   | |
It gives you a work out pushing and pulling this 540LB. beast across the floor. The bed linens are dirty and need to be washed! |
Post# 499556 , Reply# 2   2/26/2011 at 20:59 (4,779 days old) by supremewhirlpol ()   |   | |
After loading items, still room in the cylinder. |
Post# 499561 , Reply# 3   2/26/2011 at 21:04 (4,779 days old) by supremewhirlpol ()   |   | |
It needs 220V AC 3 phase power 6.5 FLA, time to plug it in to the rotary phase converter. Those Elmo motors HATE phase loss! |
Post# 499562 , Reply# 4   2/26/2011 at 21:05 (4,779 days old) by supremewhirlpol ()   |   | |
Will try some Borax this time. |
Post# 499563 , Reply# 5   2/26/2011 at 21:07 (4,779 days old) by supremewhirlpol ()   |   | |
With some Plus orange box. |
Post# 499565 , Reply# 6   2/26/2011 at 21:09 (4,779 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
I thought I heard a 3 phase converter as I had one for a Hobart 60 qt. machine.
Noisey Buggers ???? CLICK HERE TO GO TO toploader55's LINK |
Post# 499567 , Reply# 7   2/26/2011 at 21:12 (4,779 days old) by supremewhirlpol ()   |   | |
The Ipso is a rigid base machine and otherwise very dangerous to operate if not bolted to some concrete. Use this dinky whirlpool branded FL to extract the water. |
Post# 499571 , Reply# 8   2/26/2011 at 21:14 (4,779 days old) by supremewhirlpol ()   |   | |
Water extracted after prewash ->Yuck! |
Post# 499572 , Reply# 9   2/26/2011 at 21:17 (4,779 days old) by supremewhirlpol ()   |   | |
Ipso filling and splashing water every where->too much water pressure. |
Post# 499577 , Reply# 10   2/26/2011 at 21:18 (4,779 days old) by supremewhirlpol ()   |   | |
FS has been loaded->a bunch of it! |
Post# 499579 , Reply# 11   2/26/2011 at 21:20 (4,779 days old) by neptunebob (Pittsburgh, PA)   |   | |
Post# 499580 , Reply# 12   2/26/2011 at 21:22 (4,779 days old) by supremewhirlpol ()   |   | |
I think the little dinky Whirlpool just crapped out. Doesn't want to spin anymore. Have to use the Primus for extract now. |
Post# 499583 , Reply# 13   2/26/2011 at 21:26 (4,779 days old) by supremewhirlpol ()   |   | |
Just love that big cylinder! Sorry PeterH770, This machine is just too sexy! |
Post# 499605 , Reply# 14   2/26/2011 at 21:59 (4,779 days old) by supremewhirlpol ()   |   | |
video of washing bed linens. CLICK HERE TO GO TO supremewhirlpol's LINK |
Post# 499606 , Reply# 15   2/26/2011 at 22:00 (4,779 days old) by supremewhirlpol ()   |   | |
Video of rinsing the bed linens->fill CLICK HERE TO GO TO supremewhirlpol's LINK |
Post# 499960 , Reply# 17   2/27/2011 at 22:11 (4,778 days old) by COMBO52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 501979 , Reply# 19   3/6/2011 at 19:50 (4,771 days old) by supremewhirlpol ()   |   | |
Now I've seen more machines of this model rated for 35LB. Time to see if this machine can live up to its rated capacity in dry weight. The pile on the floor is equivalent of 35LB. of random dirty clothes. |
Post# 501982 , Reply# 20   3/6/2011 at 19:56 (4,771 days old) by supremewhirlpol ()   |   | |
Loading was random too. As in grabbing them and shoving them in the machine. This is the result and I didn't have to pack them in either. |
Post# 501984 , Reply# 21   3/6/2011 at 19:59 (4,771 days old) by supremewhirlpol ()   |   | |
There are several pockets of open space. Can this machine be loaded with a 35LB load without having to pack items? Yes. |
Post# 501985 , Reply# 22   3/6/2011 at 20:00 (4,771 days old) by supremewhirlpol ()   |   | |
Now lets try 40LB. This is 40LB. dry weight. |
Post# 501988 , Reply# 23   3/6/2011 at 20:05 (4,771 days old) by supremewhirlpol ()   |   | |
Again random loading, no packing. This time, not as many empty space pockets. There are some here and there. |
Post# 501990 , Reply# 24   3/6/2011 at 20:08 (4,771 days old) by supremewhirlpol ()   |   | |
Washes very well at full capacity! |
Post# 501998 , Reply# 25   3/6/2011 at 20:15 (4,771 days old) by supremewhirlpol ()   |   | |
Ok John, I told you that I'd get you V_rms values when running the Ipso. Here they are. This is V_rms measuring from legs 1>2. |
Post# 502000 , Reply# 26   3/6/2011 at 20:17 (4,771 days old) by supremewhirlpol ()   |   | |
V_rms value measuring legs 2>3. |
Post# 502001 , Reply# 27   3/6/2011 at 20:21 (4,771 days old) by supremewhirlpol ()   |   | |
V_rms value measuring legs 1>3 |
