Thread Number: 33371
Sanyo SW9010 |
Post# 502280 , Reply# 1   3/7/2011 at 20:45 (4,770 days old) by supremewhirlpol ()   |   | |
It's an impeller machine with water recirculation pump system. Duck tape covers places where top has broken away. |
Post# 502282 , Reply# 2   3/7/2011 at 20:47 (4,770 days old) by supremewhirlpol ()   |   | |
Ah! Steinbergs "Simply the Best" My favoirte when I was little, besides Sears. |
Post# 502283 , Reply# 3   3/7/2011 at 20:50 (4,770 days old) by supremewhirlpol ()   |   | |
Back-> it's quite a small, dinky machine. Doesn't weigh very much. |
Post# 502284 , Reply# 4   3/7/2011 at 20:53 (4,770 days old) by supremewhirlpol ()   |   | |
nameplate. 5LB? I doubt it will wash that and still turn the clothes over efficiently. |
Post# 502285 , Reply# 5   3/7/2011 at 20:55 (4,770 days old) by supremewhirlpol ()   |   | |
Ungrounded parts huh. A VERY fun machine! |
Post# 502286 , Reply# 6   3/7/2011 at 20:56 (4,770 days old) by supremewhirlpol ()   |   | |
Drain trap. |
Post# 502287 , Reply# 7   3/7/2011 at 20:57 (4,770 days old) by supremewhirlpol ()   |   | |
Water levels |
Post# 502288 , Reply# 8   3/7/2011 at 20:59 (4,770 days old) by supremewhirlpol ()   |   | |
Wash cycles |
Post# 502375 , Reply# 9   3/8/2011 at 09:30 (4,769 days old) by mistereric (New Jersey (Taylor Ham))   |   | |
Post# 502378 , Reply# 10   3/8/2011 at 09:44 (4,769 days old) by peteski50 (New York)   |   | |
I briefly used one of these in the mid 80's. It washed the clothes very well. If I remember correctly it had 2 deep rinses on the normal cycle and only a spin at the end. Being it used a full amount of water it makes the difference in cleaning. At least compared to todays propeller jobs that should use at least 2/3 of a tub of water!
Post# 502381 , Reply# 11   3/8/2011 at 10:01 (4,769 days old) by yogitunes (New Jersey)   |   | |
I know it would be a lot of work....but what about fiberglass/epoxy top and underneath for reinforcement, then light sanding and repaint.......
woud be stronger than new...... Eric...I liked the one I got you and Steve, but don't you wished it had a filter flo to make it close to the big one?....never knew they had this option....is there a seperate pump for this feature, I wonder if one could be added to the GE's nice machine though...I like the "wash only"...great for soaking |
