Thread Number: 33451
Possible help with THOR automagic ??? |
Post# 503458 , Reply# 2   3/12/2011 at 06:13 (4,793 days old) by perc-o-prince (Southboro, Mass)   |   | |
Thanks, Jerry. I've just sent Ross an email. Cross my fingers :-) Rich |
Post# 503462 , Reply# 3   3/12/2011 at 06:36 (4,793 days old) by kenmore58 (Rhode Island)   |   | |
Let's hope someone can come up with a solution. As you all know, a week after Rich found his Thor, one showed up in Rhode Island where I live and I now own that machine. Same problem with my machine. No matter what I do, I can't get the tub out.
Look forward to hearing any possible solutions to the problem. Ron |
Post# 503467 , Reply# 4   3/12/2011 at 07:52 (4,793 days old) by polkanut (Wausau, WI )   |   | |
Post# 503472 , Reply# 5   3/12/2011 at 08:11 (4,793 days old) by perc-o-prince (Southboro, Mass)   |   | |
Hi Tim, Yes! Rod is such a gentleman to talk with as well as deal with. Very interesting man with many interests and talents. I look forward to having this dishwasher sometime next week. I will be so much fun to play with....if I can only get the washer tub out!!! Rich |
Post# 503503 , Reply# 7   3/12/2011 at 12:17 (4,792 days old) by mickeyd (Hamburg NY)   |   | |
How long I've waited and how many times I've hoped to learn the ways of this ancient artifice. So much more exciting and intricate than I imagined. Can not tell you how much I appreciate this, Thomas.
Thank you very much. My head and scoops are spinning madly. So is the drain open throughout the operation as in your KA "warm-up" cycle? I know that the Thor pump is always on like the Frigidaire's, etc., but I can't see the answer here regarding sump, recirculation, and draining--as if you haven't done enough work already |
Post# 503565 , Reply# 11   3/12/2011 at 16:28 (4,792 days old) by perc-o-prince (Southboro, Mass)   |   | |
Where do you get it? I tried C.A.P. as well as Wallmart with no luck. I have Kroil which is a very good penetrating lubricant. It has a great ability to creep. I am just concerned about this stuff doing damage to the motor, tranny, etc... |
Post# 503571 , Reply# 12   3/12/2011 at 17:04 (4,792 days old) by swestoyz (Cedar Falls, IA)   |   | |
Post# 503598 , Reply# 13   3/12/2011 at 19:04 (4,792 days old) by perc-o-prince (Southboro, Mass)   |   | |
I did see that at Wallmart. I am trying Kroil and if this doesn't work then I'll try PB Blaster or Rust Buster...if I can get it. Thanks! Rich |
Post# 503687 , Reply# 16   3/12/2011 at 23:12 (4,792 days old) by Tomturbomatic (Beltsville, MD)   |   | |
You were very wise to rehydrate the old seals with hot water. |
