Thread Number: 33595
KUDS22 Bottom Door Issue |
Post# 505239   3/19/2011 at 18:02 (4,779 days old) by labboy (SD, CA)   |   | |
The previous owner bent the sheet metal piece that the top part (with the rubber edge) of the bottom door "hooks" onto when they deinstalled this machine. (This is the long sheet metal piece that attaches to the frame with two screws. It has two small metal tabs (in the center) that hook into the wiring shield for the wires going into the door. I have looked on various parts sites and have been unable to determine a part number or even what it is called. I tried gently bending it back but it is not possible to get it even so the bottom door fits evenly or does not pop off after closing the main door a few times.
Any suggestions? Thanks in advance! |
