Thread Number: 33619
Frigidaire Dishwasher Aqua Color circa 1960s |
Post# 505536 , Reply# 1   3/21/2011 at 06:13 (4,778 days old) by appnut (TX)   |   | |
Post# 505580 , Reply# 2   3/21/2011 at 11:26 (4,778 days old) by turquoisedude (.)   |   | |
Post# 505582 , Reply# 3   3/21/2011 at 11:30 (4,778 days old) by jamman_98 (Columbia, SC)   |   | |
Post# 505715 , Reply# 4   3/21/2011 at 20:05 (4,777 days old) by henrycsc ()   |   | |
Thanks for the info. The house also has a vintage intercom/in tube house radio that still works - just takes a few minutes to warm up. I'm in Columbia. |
Post# 505808 , Reply# 5   3/22/2011 at 08:12 (4,777 days old) by rollermatic (cincinnati)   |   | |
you can fix that leak like said above. if it's the motor seal leaking then you're pretty much out of luck as i have yet to find anyone with new seals around anywhere.
luckily mine was just leaking thru old gaskets and it now runs perfectly and doesn't leak. but if it's a spin tube and you get the leaks fix a bigger problem emerges! they don't clean well! i'm glad i got mine and i love it's "sunny yellow" color and it's novelty wash system and it's nostalgic as all get out but i would never be able to use it as a daily machine! it simply doesn't clean the dishes well! guess i'm spoiled on my kitchenaids and later model frigidaire dishmobile that i use everyday. |
Post# 505859 , Reply# 6   3/22/2011 at 12:06 (4,777 days old) by jamman_98 (Columbia, SC)   |   | |
Post# 505916 , Reply# 7   3/22/2011 at 17:26 (4,776 days old) by retromania (Anderson, South Carolina)   |   | |
Cool old Frigidaire dishwasher! |
Post# 505920 , Reply# 8   3/22/2011 at 17:54 (4,776 days old) by henrycsc ()   |   | |
Bummer to hear that it doesn't do a very good job cleaning dishes. I probably will not keep it in that case since I won't have room for 2 dishwashers. |
Post# 505922 , Reply# 9   3/22/2011 at 18:00 (4,776 days old) by retromania (Anderson, South Carolina)   |   | |
Henry: Where are you in SC? |
Post# 506910 , Reply# 10   3/26/2011 at 05:50 (4,773 days old) by henrycsc ()   |   | |
I am in Columbia, SC |
