Thread Number: 33685
kelvinator D&M dishwasher rebuild- part 1 |
Post# 506298   3/23/2011 at 21:42 (4,781 days old) by rollermatic (cincinnati)   |   | |
i bought this kelvinator dishwasher over 2 years ago from matt in grand rapids michigan. it has been sitting in my appliance room ever since, patiently waiting the day that i would tear into it!
it's a standard D&M design with two spray arms. my other two D&M dishwashers that i have rebuilt are both sears kenmore with the top roto rack. |
Post# 506299 , Reply# 1   3/23/2011 at 21:44 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506301 , Reply# 2   3/23/2011 at 21:47 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506302 , Reply# 3   3/23/2011 at 21:50 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506305 , Reply# 4   3/23/2011 at 21:52 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506306 , Reply# 5   3/23/2011 at 21:55 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506307 , Reply# 6   3/23/2011 at 21:58 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506310 , Reply# 7   3/23/2011 at 22:00 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506314 , Reply# 8   3/23/2011 at 22:08 (4,781 days old) by rollermatic (cincinnati)   |   | |
and has the cast iron pump housing as opposed to the later model plastic pump housings.
it also has a pop metal lower impeller which will no doubt require cutting off. these impellers are a real pain to remove from that motor shaft. i remember i experienced my first one in 1976 and i cut that one off also! they won't budge! |
Post# 506316 , Reply# 9   3/23/2011 at 22:10 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506317 , Reply# 10   3/23/2011 at 22:14 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506318 , Reply# 11   3/23/2011 at 22:16 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506319 , Reply# 12   3/23/2011 at 22:18 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506321 , Reply# 13   3/23/2011 at 22:20 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506323 , Reply# 14   3/23/2011 at 22:22 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506324 , Reply# 15   3/23/2011 at 22:27 (4,781 days old) by rollermatic (cincinnati)   |   | |
somewhat but i'm going to work on it some more with a small wire brush in my drill before installing it back.
i will also use some sealant around the rim of the rubber on the new seal i press into this housing. those outer 8 holes bolt this housing to the bottom of the tub. the inner 4 holes bolt the plastic wash pump to this cast iron drain pump housing. the motor bolts to the bottom of this cast iron housing. |
Post# 506325 , Reply# 16   3/23/2011 at 22:29 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506327 , Reply# 17   3/23/2011 at 22:34 (4,781 days old) by rollermatic (cincinnati)   |   | |
and cleaned the shaft where it fits in the bearings. used a very fine steel wool and wd 40.
then i applied a nice dose of 3 in one 'motor' oil. put it all back together and connected it to the dishwasher wiring and ran it thru several cycles. it runs great, does not overheat at all and is very quiet! |
Post# 506328 , Reply# 18   3/23/2011 at 22:38 (4,781 days old) by rollermatic (cincinnati)   |   | |
removal and cleanup.
first, the 2 gaskets. these are readily available at part stores on line and i think i have a couple new one's here. but i had such good luck with the cork material i used on the frigidaire spin tube i just finished rebuilding that i'm going to make new gaskets for this kelvinator out of that same material. |
Post# 506329 , Reply# 19   3/23/2011 at 22:39 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506331 , Reply# 20   3/23/2011 at 22:42 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506333 , Reply# 21   3/23/2011 at 22:46 (4,781 days old) by rollermatic (cincinnati)   |   | |
plate that covers the lower pump housing and lower impeller. the wash pump sits on top of this plate. without this plate in plate the dishwasher will not drain properly.
it is basically a cover for the lower drain pump. later models are partly plastic. but again this is an oldie! i would love to know the age of this machine! |
Post# 506334 , Reply# 22   3/23/2011 at 22:49 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506335 , Reply# 23   3/23/2011 at 22:53 (4,781 days old) by rollermatic (cincinnati)   |   | |
decorative peice that sits on D&M pumps with all those little holes in it. i remember it well when i was a kid, i always wondered what it's purpose was. i still do.
i remember someone on the site here said it was to hide the view of the sump area that was notorious for rusting and discoloring on all D&M machines. i wonder if this is true? |
Post# 506337 , Reply# 24   3/23/2011 at 22:57 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506339 , Reply# 25   3/23/2011 at 22:59 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506344 , Reply# 26   3/23/2011 at 23:07 (4,781 days old) by rollermatic (cincinnati)   |   | |
these are on e bay all the time for about 3 bucks!
from top left this kit consists of the seal itself, the bottom impeller, instructions, shims and o ring, top impeller, and the 2 cardboard tools to center and measure proper distances of pump parts. round tube is for centering motor and shaft on cast iron housing. other peice will guage the height of the lower impeller on shaft and seal. those 3 shims are used for this purpose. height must be exact or top impeller will scrape against pump housing. |
Post# 506345 , Reply# 27   3/23/2011 at 23:11 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506346 , Reply# 28   3/23/2011 at 23:12 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506347 , Reply# 29   3/23/2011 at 23:13 (4,781 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Wow, the last of the AMC-built Kelvy's!!!!
If my grandma & grandpa had a dishwasher (back when my grandpa worked for that Grand Rapids-based co.) that would surely be it--and in avocado to go w/ their fridge & stove (and the stove had NO name-plate on it, either,--unless it fell off!) Everyone got real mad at my attempts at "replacing it", too--with ones I pulled off of discarded appliances or the one I pried off of the cooler/freezer in the school lunch room (where we bought our milk & ice cream bars) or "home-made, handwritten ones", and even the RCA Whirlpool nameplate from the old washing machine control panel I played around with before my mom made me throw it away... (It would have passed, I think...) -- Dave |
Post# 506349 , Reply# 30   3/23/2011 at 23:15 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506351 , Reply# 31   3/23/2011 at 23:16 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506353 , Reply# 32   3/23/2011 at 23:19 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506355 , Reply# 33   3/23/2011 at 23:24 (4,781 days old) by rollermatic (cincinnati)   |   | |
next thing on the list is to paint the sump, reinstall the pump and motor with it's new seal kit and then take it for a test ride.
hope to have it all back together in about 2 weeks or so. will do a post of the actual rebuilding of the pump and assembly. thanks for lookin. this is a great old classic D&M machine! |
Post# 506357 , Reply# 34   3/23/2011 at 23:30 (4,781 days old) by rollermatic (cincinnati)   |   | |
Post# 506359 , Reply# 35   3/23/2011 at 23:40 (4,781 days old) by DaveAMKrayoGuy (Oak Park, MI)   |   | |
Gramps worked for Kelvy, for Ford, for Chrysler, for GM--and even Kelsey Hayes making airplane parts during WWII...!
so,--Yes!--Kelvinator was such a formidable brand, and too bad, along w/ Greenville, Michigan's own GIBSON brand, with Beton Harbor's WHIRLPOOL company, it could never compete! (An example was just how many mistrusted that brand w/ their laundry equipment, while that name was at least seen on one appliance in the kitchen or would at least own a Gibson or Kelvinator freezer!) Sure would be nice to see a resurrection, (though it's unfortunately due to its demise, really) if it were to keep Michigan working! --Dave (Thanks, and hope I didn't spoil the continuity of your photos of "your work in progress"...) |
Post# 506385 , Reply# 36   3/24/2011 at 07:20 (4,781 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Peter thanks for taking the time to show the pump rebuilding process of these machines. Unfortunately I have easily rebuilt more than a couple a hundred of these in the home when things went wrong. The easy way to remove the old pot-metal drain impeller is to just heat it with a propane torch till the rubber seal starts to smoke a little and then give it a sideways whack and it always comes off very easily. Yes I was the one that said that the round black plastic guard was designed to hide the enviable rust that often showed up in the first year of use. The problem with the guard is that people would not see all sorts of small objects and broken glass etc laying in the sump area and then the items would just stay there with a much greater chance that they would work themselves into the grinder and do damage the the pump etc. I always threw them away when I had to remove them to reduce the chance of a callback and another ruined pump. |
Post# 506537 , Reply# 37   3/24/2011 at 17:45 (4,780 days old) by turquoisedude (.)   |   | |
Post# 507519 , Reply# 38   3/28/2011 at 07:51 (4,777 days old) by rollermatic (cincinnati)   |   | |
combo52. i have never used a torch on these before but the next one i get (and i'm sure there will be another some day) i will try the heat method.
paul, these are not hard to rebuild at all and pump seals are plentiful and cheap. i have done about 10 of them over the last 35 years and there are still lots of D&M dishwashers out there. |
