Thread Number: 33702
Motor on D&M (Kenmore) Dishwasher Fries |
Post# 506556 , Reply# 1   3/24/2011 at 18:50 (4,774 days old) by coldspot66 (Plymouth, Mass)   |   | |
Sounds like the wires might be miswired on the relay. Or a bad relay. did the new motor come with a new relay? |
Post# 506670 , Reply# 4   3/25/2011 at 08:22 (4,774 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Here is the installation instructions that come with a GE replacement motor built for D&M DWs. These motors have always come with a new relay and either you have a bad relay or the motor is missed wired, do note that the wire colors did change on some motors so going by the original wire colors may get you into trouble. |
Post# 506811 , Reply# 6   3/25/2011 at 16:10 (4,773 days old) by cornutt (Huntsville, AL USA)   |   | |
You might want to check the resistance of both of the start windings with an ohmmeter and make sure they are still within spec. If they are, use the motor and no worries. |
Post# 506859 , Reply# 7   3/25/2011 at 19:10 (4,773 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
