Thread Number: 33743
Blue box mod1 |
Post# 507126   3/26/2011 at 23:47 (4,772 days old) by supremewhirlpol ()   |   | |
Looking at the following pictures and comparing them, what is different about the Whirlpool BD? |
Post# 507127 , Reply# 1   3/26/2011 at 23:52 (4,772 days old) by supremewhirlpol ()   |   | |
Ok, Here is picture 2. Also, what do you think these "changes" do? If you need hints, please ask. |
Post# 507144 , Reply# 2   3/27/2011 at 01:36 (4,772 days old) by foraloysius (Leeuwarden, Friesland, the Netherlands)   |   | |
Post# 507187 , Reply# 3   3/27/2011 at 06:27 (4,772 days old) by akronman (Akron/Cleveland Ohio)   |   | |
On 2 of my machines, I added switches to a) stop the timer motor and allow extra time anywhere in a cycle, and b) override the water level sensor to allow me to suck suds back up from the drain tub during agitation.
You've added a switch on top of the main console, and another one at the right side, maybe same 2 ideas as me? |
Post# 507209 , Reply# 4   3/27/2011 at 08:42 (4,772 days old) by markk290 ()   |   | |
The switch on the side of the console is for shutting off the suds valve so the wash water isn't saved every time. Not sure what the other switch is for. |
Post# 507222 , Reply# 6   3/27/2011 at 09:43 (4,772 days old) by cfz2882 (Belle Fourche,SD)   |   | |
so it lights up automaticly when in the dark? |
Post# 507429 , Reply# 8   3/27/2011 at 21:11 (4,771 days old) by supremewhirlpol ()   |   | |
Originally the timer dial lights up, but has a busted bulb. |
Post# 507430 , Reply# 9   3/27/2011 at 21:13 (4,771 days old) by supremewhirlpol ()   |   | |
There is some space in the console but not much. |
Post# 507434 , Reply# 11   3/27/2011 at 21:25 (4,771 days old) by supremewhirlpol ()   |   | |
The cabinet had to be modified too. What this picture does not show is the additional cutting I had to do to the right rear gusset bracket later. |
Post# 507436 , Reply# 12   3/27/2011 at 21:27 (4,771 days old) by supremewhirlpol ()   |   | |
The fixture has been mounted, and console area cleaned. |
Post# 507439 , Reply# 13   3/27/2011 at 21:31 (4,771 days old) by supremewhirlpol ()   |   | |
Here is the ballast kit. I'm going to be very vague for the wiring side, as I don't want future viewers who know nothing about electric to attempt this. |
Post# 507441 , Reply# 14   3/27/2011 at 21:33 (4,771 days old) by supremewhirlpol ()   |   | |
Picture of lamp start test. |
Post# 507444 , Reply# 15   3/27/2011 at 21:35 (4,771 days old) by supremewhirlpol ()   |   | |
Lamp is out of start stage->fully on. |
Post# 507448 , Reply# 16   3/27/2011 at 21:37 (4,771 days old) by supremewhirlpol ()   |   | |
Photoelectric switch mounted. |
Post# 507449 , Reply# 17   3/27/2011 at 21:39 (4,771 days old) by supremewhirlpol ()   |   | |
Just a mess of wires... |
Post# 507454 , Reply# 18   3/27/2011 at 21:41 (4,771 days old) by supremewhirlpol ()   |   | |
Button up the console->for now |
Post# 507458 , Reply# 19   3/27/2011 at 21:44 (4,771 days old) by supremewhirlpol ()   |   | |
The first part of this mod is finished. |
Post# 508039 , Reply# 22   3/29/2011 at 20:34 (4,769 days old) by supremewhirlpol ()   |   | |
Now its time for mod1, part 2. |
Post# 508042 , Reply# 23   3/29/2011 at 20:37 (4,769 days old) by supremewhirlpol ()   |   | |
Here is the underside of the top |
Post# 508043 , Reply# 24   3/29/2011 at 20:41 (4,769 days old) by supremewhirlpol ()   |   | |
MOD1, part 2 is the modification of the splash guard. I have an extra just in case I mess up. The other is slightly different, but will work. |
Post# 508047 , Reply# 26   3/29/2011 at 20:52 (4,769 days old) by supremewhirlpol ()   |   | |
Here is a picture of the amount of light in the machine from cutting out places on the splash guard. The plexiglass has not been put in. |
Post# 508049 , Reply# 27   3/29/2011 at 20:54 (4,769 days old) by supremewhirlpol ()   |   | |
The areas have been cut out. |
Post# 508050 , Reply# 28   3/29/2011 at 20:56 (4,769 days old) by supremewhirlpol ()   |   | |
Splash guard drying from being cleaned in preparation for the plexiglass. |
Post# 508051 , Reply# 29   3/29/2011 at 20:58 (4,769 days old) by supremewhirlpol ()   |   | |
Plexiglass placement |
Post# 508052 , Reply# 30   3/29/2011 at 21:00 (4,769 days old) by supremewhirlpol ()   |   | |
Sealer applied to areas. Time for plexiglass and sealer to cure |
Post# 508138 , Reply# 32   3/30/2011 at 07:05 (4,769 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 508307 , Reply# 33   3/31/2011 at 00:17 (4,768 days old) by tolivac (greenville nc)   |   | |
Graingers in my area was the first thing I tried-the store here didn't have the bulbs.Same with D&M appliance parts-and the lighting stores here-so my flourscent lights on my two washers that use them are dark. |
Post# 508326 , Reply# 34   3/31/2011 at 06:57 (4,768 days old) by mrb627 (Buford, GA)   |   | |
Post# 508332 , Reply# 35   3/31/2011 at 07:51 (4,768 days old) by yogitunes (New Jersey)   |   | |
Post# 508407 , Reply# 37   3/31/2011 at 15:01 (4,767 days old) by supremewhirlpol ()   |   | |
Now look at the underside. Hardly no chipping. Lesson: If you want to keep the top porcelain finish looking good(the edges), cut from the bottom side. |
Post# 508417 , Reply# 38   3/31/2011 at 15:50 (4,767 days old) by yogitunes (New Jersey)   |   | |
Post# 508443 , Reply# 40   3/31/2011 at 18:03 (4,767 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 508806 , Reply# 41   4/2/2011 at 15:59 (4,765 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 509251 , Reply# 42   4/4/2011 at 16:32 (4,763 days old) by supremewhirlpol ()   |   | |
Thanks John, Darren! Now! A tub/"wash" light has been added, but there is STILL a problem. What's wrong with this picture? |
Post# 509289 , Reply# 43   4/4/2011 at 19:26 (4,763 days old) by yogitunes (New Jersey)   |   | |
