Thread Number: 33779
Samsung washer High level Delicate/hand wash cycle |
Post# 507857 , Reply# 3   3/29/2011 at 08:57 (4,748 days old) by whitetub (Montreal, Canada)   |   | |
Thanks for your input. I will use my Normal cycle most of the time, as usual, if you all say that less is more. But I have to admit, a load that swishes and tumbles in more water is more entertaining to watch. :) thanks |
Post# 507884 , Reply# 4   3/29/2011 at 10:42 (4,748 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 507887 , Reply# 5   3/29/2011 at 10:55 (4,748 days old) by PeterH770 (Marietta, GA)   |   | |
Post# 507890 , Reply# 6   3/29/2011 at 11:04 (4,748 days old) by mrb627 (Buford, GA)   |   | |
I used to use the Delicate cycle on my LG to wash wrinkle free clothing that only really needed a freshing up. My reasoning was that the cycle was shorter so I didn't have to listen to the machine squeak and squeal like during the normal 55 min cycle. And the extra moisture left in the clothes helped to steam out the wrinkles better in the dryer which rattled through its cycle.
Malcolm |
Post# 507931 , Reply# 7   3/29/2011 at 14:25 (4,748 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 507932 , Reply# 8   3/29/2011 at 14:28 (4,748 days old) by mark_wpduet (Lexington KY)   |   | |
Post# 507943 , Reply# 9   3/29/2011 at 15:18 (4,747 days old) by whitetub (Montreal, Canada)   |   | |
I never tried the express wash. I think it's called Fast Wash on my Samsung machine. I know the Permanent Press uses more water, but the tumbling is not as vigorous. And I have to select heavy soil to get to 48 minute cycle. I will give Fast Wash a try and see what happens. |
Post# 508097 , Reply# 10   3/30/2011 at 00:59 (4,747 days old) by MattL (Flushing, MI)   |   | |
Mark, I never bumped the water levels up too much, found the settings to be too touchy. Got a moderate increase and left it there. when I lit the tub I could really see the action, and found in smaller loads that I mostly do, less in more. |
Post# 508196 , Reply# 11   3/30/2011 at 13:19 (4,747 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Will wash performance with a higher water level be affected not only dynamically but also chemically! Using the same recommended dose of detergent that you’d use for a given size load of clothes will have a lower concentration having been diluted in a greater amount of water defeating, as a result, its cleaning power.
Unless you decide to increase the amount of detergent used proportionally to the higher water intake... in that case you might benefit of the same cleaning power as you would in normal conditions but you would still suffer the dynamic consequences discussed above (depending on the size of the load of course). In addition, this would favour the creation of some conditions (like the formation of excessive suds) which would inevitably make matters worse. I agree with you about... 'more water, more fun to watch' though :-P |
Post# 508210 , Reply# 14   3/30/2011 at 14:39 (4,747 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
The rinses in the "Express Wash" cycle, fortunately, use the same amount of water as the wash, so yes it does do pretty good on the rinses. Actually sometimes I would like more water for the rinses, but oh well.
F.Y.I... The express wash on my KM Elite is 30 minutes if I don't change anything. The "soil level" defaults to "light" which equates to a wash that's less then 5 minutes (it seems like 3 minutes). So if I change the soil level to "heavy" the wash is around 10-12 minutes (I haven't timed it) and I always add an extra rinse. As I said before, I'm happier with it because it does use more water then the Normal cycle and at 49 minutes, is 6 minutes less then "Normal" w/o an extra rinse.
Kevin |
Post# 508219 , Reply# 15   3/30/2011 at 15:40 (4,746 days old) by mark_wpduet (Lexington KY)   |   | |
I have NO clue how you would do it on a GE! Those are different than WP. With mine there was a person on a forum who had pictures of each step that he did to do this. Essentially, there is an ever so tiny screw that you have to turn a certain way, let the machine fill to see what the new level is/drain/ turn the screw more, drain, retry until you get the water level you want.
The problem I had is that I could not find the right water level. It was either WAY too much or factory default. I could never get the in between that I wanted. After working with it a while I finally got it to use MORE water but in my case it WASN'T easy and I just left it alone from there and it's been working fine ever since. I'm thinking I'm getting maybe two more gallons each fill. I don't think this trick works on the NEWER Duets (I could be wrong) Mine is six years old so it happens to be one of the ones that was exactly like the model the person in the forum demonstrated this on. I guess you can try to Google it and see if you can find anything with your model. Here is a video of mine doing a drain, spin, then rinse that I posted on youtube a while back CLICK HERE TO GO TO mark_wpduet's LINK |
