Thread Number: 33785
KDS-18 Stored since 1983 help!! Appnut, stevet!! |
Post# 507729 , Reply# 1   3/28/2011 at 18:55 (4,774 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 507825 , Reply# 3   3/29/2011 at 05:24 (4,774 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 508022 , Reply# 12   3/29/2011 at 20:08 (4,773 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
Post# 508149 , Reply# 13   3/30/2011 at 07:51 (4,773 days old) by alabamboy ()   |   | |
and take photos as I go so you can see the progress. Thanks again Steve!!! |
Post# 508180 , Reply# 14   3/30/2011 at 11:20 (4,773 days old) by alabamboy ()   |   | |
Leaned the machine back removed the motor cap to find the culprit(hopefully), the dirty starter switch. |
Post# 508181 , Reply# 15   3/30/2011 at 11:23 (4,773 days old) by alabamboy ()   |   | |
for 15-20 minutes and used an old toothbrush to gently scrub area careful to not bend contacts |
Post# 508182 , Reply# 16   3/30/2011 at 11:26 (4,773 days old) by alabamboy ()   |   | |
works(I know its a bad photo). Thanks again Steve, I learned a lot!!! |
Post# 508195 , Reply# 17   3/30/2011 at 13:15 (4,772 days old) by rp2813 (Sannazay)   |   | |
Post# 508256 , Reply# 18   3/30/2011 at 19:40 (4,772 days old) by stevet (West Melbourne, FL)   |   | |
You are very welcome. There is no other place on earth that you can get answers to questions like yours. And thanks to all the other guys too. We are an awesome team! |
Post# 508314 , Reply# 19   3/31/2011 at 03:22 (4,772 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
in a lot of Delco motors. Especially those used in the early rollermatic machines and in the Bendix Gyromatics from 1950-1958.
Switches are mechanical and so they will fail first. Dirt and arcing are the culprits on contacts. Whenever I rebuild a Gyromatic I always break down the centrifugal switch , lube the weight and clean the contacts with emery paper. You want those contact buttons to be as smooth and flat as possible.
Good work guys, this is an awesome site for us all. |
