Thread Number: 33864
Second break down in 10 years! sheesh so unreliable! |
Post# 508829   4/2/2011 at 17:49 (4,765 days old) by ricky5050 (Durham Britain)   |   | |
Yes this is the correct forum!
My 10 year used washing machine developed a fault this week! but trust me this is the correct forum, its been in use for 10 years since i moved in to my first home, but up till then it had not been connected since its manufacture in 1965.
As most of you may know i bought it from a house where it had stood in a pantry since being delivered in the 60's
Its been in use since then for about 3-4 loads a week and in those 10 years its only needed new belts and this week the timer stopped ticking.
It has always been a little tempremental sometimes when starting it wont tick around but normally stopping it and turning the dial 360 degrees but then off it goes and works fine, but this week it wouldnt go and running it through the cycle manually didnt work well as it missed the spins.
So i took apart to see if there was a problem with the timer motor
here are some pictures
Richard
Post# 508830 , Reply# 1   4/2/2011 at 17:50 (4,765 days old) by ricky5050 (Durham Britain)   |   | |
Post# 508831 , Reply# 2   4/2/2011 at 17:52 (4,765 days old) by ricky5050 (Durham Britain)   |   | |
Post# 508834 , Reply# 3   4/2/2011 at 17:53 (4,765 days old) by ricky5050 (Durham Britain)   |   | |
Post# 508836 , Reply# 4   4/2/2011 at 17:55 (4,765 days old) by ricky5050 (Durham Britain)   |   | |
Post# 508838 , Reply# 5   4/2/2011 at 18:02 (4,765 days old) by ricky5050 (Durham Britain)   |   | |
Post# 508843 , Reply# 6   4/2/2011 at 18:28 (4,765 days old) by ricky5050 (Durham Britain)   |   | |
The timer motor has the following marking and is a sealed unit so not sure if i can get a replacement or if i need one as when i put it back together it worked fine. So ill have to see how it goes
Markings
Control of America model 411 50 c 3 w 220v 21Κ rpm
I have put a video together of it working with top removed so you can see it shake and shudder!
CLICK HERE TO GO TO ricky5050's LINK |
Post# 508890 , Reply# 7   4/2/2011 at 21:24 (4,765 days old) by A440 ()   |   | |
Great Video Ricky! Hope you get it working as new again. Such a great looking machine! Brent |
