Thread Number: 33877
Welcoming another Frigidaire into the Family |
Post# 509070   4/3/2011 at 19:48 (4,769 days old) by joelippard (Hickory)   |   | |
Post# 509071 , Reply# 1   4/3/2011 at 19:48 (4,769 days old) by joelippard (Hickory)   |   | |
Post# 509072 , Reply# 2   4/3/2011 at 19:49 (4,769 days old) by joelippard (Hickory)   |   | |
Post# 509073 , Reply# 3   4/3/2011 at 19:50 (4,769 days old) by joelippard (Hickory)   |   | |
Post# 509074 , Reply# 4   4/3/2011 at 19:51 (4,769 days old) by joelippard (Hickory)   |   | |
Post# 509075 , Reply# 5   4/3/2011 at 19:52 (4,769 days old) by mrb627 (Buford, GA)   |   | |
Post# 509083 , Reply# 6   4/3/2011 at 21:04 (4,769 days old) by appliancelou (Lyndhurst New Jersey)   |   | |
Post# 509090 , Reply# 7   4/3/2011 at 21:52 (4,769 days old) by cornutt (Huntsville, AL USA)   |   | |
Interesting that it's designated "1-18" on the unit itself. I wonder how many of them have that? |
Post# 509093 , Reply# 8   4/3/2011 at 22:07 (4,769 days old) by GadgetGary (Bristol,CT)   |   | |
Post# 509096 , Reply# 9   4/3/2011 at 22:23 (4,769 days old) by joelippard (Hickory)   |   | |
Malcolm I'll see what I can do about getting you a video of it sometime this week.
Every 1-18 I have ever seen has the designation on the control panel somewhere.
GadgetGary, it's common for a slight slowdown on agitation if the load is really big and on spin when the spray rinse is going on. It also is common that it ramps up to spin speed slowly, typically staring the spin cycle on low speed, getting most of the water out and then ramping up to full speed. What I would do in your case is open it up and check the belt, it should have 1/2 inch deflection when you push on it, otherwise it's too loose and needs tightening. Just let me know and I can point you to the instructions, they're here on the site. It also sounds like a roller cleaning could be in order as well, all you need is a good lint free cloth and a bottle of rubbing alcohol, rotate them manually and clean them, see how things go after that. In order to change the belt you must remove all the hoses from the pump, there are four of them and I found that manuvering at the backside of the pump to deal with those standard pinch style clamps was a hellish proposition and I replaced the clamps I removed with an easier to manage band style clamp with nut driver heads. |
Post# 509099 , Reply# 10   4/3/2011 at 22:29 (4,769 days old) by GadgetGary (Bristol,CT)   |   | |
Thanks for your suggestions. I really love this machine. It brings back memories of my mothers 1967 Rapidry 1000.
The agitation starts out strong and then after about two minutes, it slows down and speeds up intermittently. When the spin starts, sometimes it takes about 1 min before the water starts coming out of the drain hose, then, it drains and goes into a pretty fast spin.
Will try to clean the rollers and see what happens.
Thanks again!
Post# 509100 , Reply# 11   4/3/2011 at 22:32 (4,769 days old) by GadgetGary (Bristol,CT)   |   | |
Post# 509102 , Reply# 12   4/3/2011 at 22:41 (4,769 days old) by peteski50 (New York)   |   | |
Post# 509105 , Reply# 13   4/3/2011 at 23:29 (4,769 days old) by PhilR (Quebec Canada)   |   | |
Post# 509115 , Reply# 14   4/4/2011 at 01:23 (4,769 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 509132 , Reply# 15   4/4/2011 at 06:06 (4,769 days old) by kenmore700bill (Lodi NJ)   |   | |
Post# 509136 , Reply# 16   4/4/2011 at 07:13 (4,769 days old) by bajaespuma (Connecticut)   |   | |
Post# 509153 , Reply# 17   4/4/2011 at 10:12 (4,768 days old) by joelippard (Hickory)   |   | |
Post# 509157 , Reply# 18   4/4/2011 at 10:26 (4,768 days old) by dishwashercrazy (West Peoria, IL)   |   | |
Joe, Nice looking 1-18 for sure. According to the Appliance411 website for dating major appliances (link below), your machine was built in August 1977. Mike CLICK HERE TO GO TO dishwashercrazy's LINK |
Post# 509166 , Reply# 19   4/4/2011 at 10:57 (4,768 days old) by mickeyd (Hamburg NY)   |   | |
Post# 509190 , Reply# 20   4/4/2011 at 12:07 (4,768 days old) by laundromat (Hilo, Hawaii)   |   | |
Post# 509193 , Reply# 21   4/4/2011 at 12:24 (4,768 days old) by joelippard (Hickory)   |   | |
Post# 509232 , Reply# 22   4/4/2011 at 14:12 (4,768 days old) by yogitunes (New Jersey)   |   | |
Does anyone know what all the extra hoses comming from the trap, going to the pump, and one is "T"ed off actually do.......
aside from the 2 big hoses, in/out for drain......and then 2 smaller ones in/out for the filter......and then a "T" off the filter input, and one going into the top of the pump....puzzled.... I got a new belt from PepBoys, they matched one up....aside from those clamps as mentioned, was easier to replace than I thought......for the motor, only remove the front bolts, the rear ones just need loosened, and the motor plate slides forward and off, or will tilt enough to get the belt out and replace.... Brake cleaner, from PepBoys also, works great on the rollers, just line the underneath with paper towels, the spray removes any oils or grease from the rollers while turning by hand, and dries in an instant....will also clean that base pan to a sparkle.... Nice machines guys....... I got one from Darren, fixing a small leak, and should be up and running soon......this is my first one, ever, absolutely amazing machine to watch in motion....fascinating.......videos just don't do it justice! one thing I am changing on mine is the small drain hose that comes with these......the hose comming up from the pump is a little larger than an inch, so I a trying a new port and larger drain hose to see if it will pump out faster....but still a powerful pump with the small hose and slow speed... |
Post# 509310 , Reply# 23   4/4/2011 at 20:50 (4,768 days old) by swestoyz (Cedar Falls, IA)   |   | |
Ok - this might be my favorite 1-18 panel now. Sooooo cool.
Checking the 1921-1977 Frigidaire model index, they do list a WKC for 1977. I'm wondering if it is a typo (not the first I've found) and they meant to list out WCK. Happy to see they were still proud enough of their product to clearly state "product of General Motors". Congrats on the beauty! Ben |
Post# 510506 , Reply# 24   4/9/2011 at 20:55 (4,763 days old) by rollermatic (cincinnati)   |   | |
of your 1-18! love that control panel on that one!!
the one i have used to slow down as well before i rebuilt it. on mine it was caused by dirty rollers as well as a water leak thru the tub seal which affected the rollers themselves. once i rebuilt it and got that leak stopped it runs perfectly! great pics, great machine!!! |
