Thread Number: 33905
Strange grinding noise |
Post# 509468 , Reply# 1   4/5/2011 at 13:27 (4,741 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 509469 , Reply# 2   4/5/2011 at 13:33 (4,741 days old) by Hunter (Colorado)   |   | |
it's when the machine is agitating, not filling or emptying. |
Post# 509479 , Reply# 3   4/5/2011 at 14:31 (4,741 days old) by coldspot66 (Plymouth, Mass)   |   | |
Is it more pronounced during a spin cycle? |
Post# 509487 , Reply# 4   4/5/2011 at 15:05 (4,741 days old) by laundromat (Hilo, Hawaii)   |   | |
When I had my KitchenAid front loaders, a friend's bra strap got caught inbetween the inner and outer tubs. It took a few loads to loosen it enough and it eventually broke down into small particles that went into the button catcher where I was able to remove it. It sounds to me like you have something either caught inbetween the tubs or something like a screw stuck in one of the tub perferations.I would get a flashlight and check all the holes in the tub first.
Post# 509488 , Reply# 5   4/5/2011 at 15:06 (4,741 days old) by Hunter (Colorado)   |   | |
Doesn't seem to make a sound during spin.
I'll check about the foreign object. |
Post# 509496 , Reply# 6   4/5/2011 at 16:05 (4,741 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 509504 , Reply# 7   4/5/2011 at 16:32 (4,741 days old) by Hunter (Colorado)   |   | |
And I will call and get it looked at much as I need to. |
Post# 509617 , Reply# 8   4/6/2011 at 02:08 (4,741 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Grindng noise on modern washers mean: "Hey, my manufacturer needs more money! Please let me die! I've reached my expiration date and i'm going to self destruct!" |
Post# 509635 , Reply# 9   4/6/2011 at 05:26 (4,740 days old) by aquarius8000 ()   |   | |
-It could be the bearings -The motor brushes -damage to the drum From aquarius8000 (Chris) |
Post# 509813 , Reply# 10   4/6/2011 at 20:28 (4,740 days old) by Hunter (Colorado)   |   | |
They did replace the motor and it works MUCH better than before. Damage to the drum is possible. |
Post# 509815 , Reply# 11   4/6/2011 at 20:34 (4,740 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 509945 , Reply# 12   4/7/2011 at 07:48 (4,739 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
The drum, spider, bearings & water seal have no connection to the motor on a WP FL washer and problems with these items will not cause motor problems [ unless water is leaking from the main shaft area on the motor ] so you could have a separate problem. To everyone it is very difficult to diagnose problems on the internet and much more so if you don't give out the model and serial #s thanks. |
Post# 510025 , Reply# 13   4/7/2011 at 16:36 (4,739 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Post# 510029 , Reply# 14   4/7/2011 at 17:00 (4,739 days old) by hoover1100 (U.K.)   |   | |
Is most pronounced at the start of the drum revolving, it could possibly be a worn or damaged belt, which would be very cheap and easy to replace. Matt |
Post# 510060 , Reply# 15   4/7/2011 at 19:57 (4,739 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
