Thread Number: 33989
Retro look SMEG washer... |
Post# 510677   4/10/2011 at 17:25 (4,757 days old) by bellalaundry (St. Catharines, Ontario, Canada)   |   | |
Is this washer for real or concept? I absouletly love it!
Have a look... CLICK HERE TO GO TO bellalaundry's LINK on eBay |
Post# 510704 , Reply# 1   4/10/2011 at 18:39 (4,757 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
Post# 510711 , Reply# 2   4/10/2011 at 19:01 (4,757 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Post# 510712 , Reply# 3   4/10/2011 at 19:08 (4,757 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
I saw those machine sin paraguay, they are really cute. There's also the dishwasher and the one door fridge with the same design. The washer has two options, with and without the small sink and the sink operation is completelly separate from the washer. The washer is fully automatic like any other european front loader and it's a little bit bigger than on pictures. |
Post# 510839 , Reply# 6   4/11/2011 at 13:30 (4,756 days old) by thomasortega (El Pueblo de Nuestra Señora de Los Angeles de Porciúncula)   |   | |
Isn't this dishwasher also cute? CLICK HERE TO GO TO thomasortega's LINK |
Post# 511194 , Reply# 8   4/13/2011 at 01:28 (4,755 days old) by jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 511202 , Reply# 9   4/13/2011 at 05:35 (4,755 days old) by aquarius1984 (Planet earth)   |   | |
Just to clarify to pondering members outside the UK that NOT ALL PLASTIC outer tubs cannot have bearing changes.
From 1983 to 2000 all UK made Hotpoint Washers from the start of the 95 series to the end of the WM50 and WM60 series machines all had plastic outer tubs which bearings can be changed to repair the machine if that was the issue. I even believe some of the WMA series machines had changeable bearings albeit a tough job to do. Same was for Servis whom used a plastic tub in their machines from 1885 to 1991. Neither makes of machines suffered Mould issues either just because they had plastic tubs which is another myth that seems to get portrayed here. In the mid to late 90s Hoover machines were repaired easily enough with bearings in their plastic tubs too. Seems like the advent of Moulded plastic tubs with non replaceable bearings started around the time manufacturers either got bought out by Italian companies like Indesit did with Hotpoint or Hoover did with Candy and introduced their machines with UK Makes badges on. Not sure if AEG produced some plastic tub machines in Germany and if they too had changeable bearings or not. Perhaps one of the AEG fans could clarify? |
