Thread Number: 33996
Maytag 606 Squeals |
Post# 510778   4/11/2011 at 03:13 (4,755 days old) by AutowasherFreak ()   |   | |
My 606 squeals for a few seconds at the beginning of each spin cycle. I'm guessing bearings. |
Post# 510786 , Reply# 1   4/11/2011 at 06:29 (4,755 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
More likely the the main drive belt than bearings. Tilt the machine back and lift off the belts, if the cloth covering is worn off the sides of the main drive belt you need a new belt. The main DB is the thicker of the two, the pump belt is not critical and unless it is cracked and frayed it will work fine, the PB will usually out live the washer. If there is oil on the pulleys use some old rags and solvent to fully clean all around the pulleys. You should also take the front off the washer and make sure the motor assembly moves easily toward the center of the machine and returns quickly on its own, if not add a few drops of light oil to the four corners of the motor carriage and work the motor assemble back and fourth until it moves freely. |
Post# 510843 , Reply# 2   4/11/2011 at 14:24 (4,755 days old) by AutowasherFreak ()   |   | |
Thanks I will check the belts and motor in a little bit. The belts aren't very old maybe a month or two short of a year. |
Post# 510867 , Reply# 4   4/11/2011 at 16:46 (4,754 days old) by AutowasherFreak ()   |   | |
They best not be Tom, or I will have to kick some major butt, LOL. I'm going to check the belts in a bit. |
Post# 510899 , Reply# 6   4/11/2011 at 19:25 (4,754 days old) by appnut (TX)   |   | |
Post# 510901 , Reply# 7   4/11/2011 at 19:28 (4,754 days old) by AutowasherFreak ()   |   | |
I know this is going to sound a little strange, but I have never seen that movie, LOL. |
