Thread Number: 34030
kds-17 will not start |
Post# 511204 , Reply# 1   4/13/2011 at 05:53 (4,733 days old) by toploader55 (Massachusetts Sand Bar, Cape Cod)   |   | |
Post# 511232 , Reply# 2   4/13/2011 at 07:51 (4,732 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
I gather you are turning the timer shaft with the lower access panel removed. Any way something is wrong electrically I would start with the door interlock switch inside the top right hand side of the door, and be sure that the metal plunger that pushes the switch lever is still there and contacting the lever when the door is closed and latched. |
