Thread Number: 3410
Maytag A606 |
Post# 84756 , Reply# 1   9/23/2005 at 11:45 (6,786 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
I had a similar problem with my A606. See this thread: CLICK HERE TO GO TO kenwashesmonday's LINK |
Post# 84854 , Reply# 4   9/23/2005 at 21:00 (6,786 days old) by kenwashesmonday (Carlstadt, NJ)   |   | |
One more thing, when you put the top of the tub back on, you just need to make sure it clears the top of the inner tub, and the top of the machine. The clearance is sort of tight, it just fits. Ken |
Post# 85148 , Reply# 5   9/25/2005 at 15:06 (6,784 days old) by goatfarmer (South Bend, home of Champions)   |   | |
If you're talking about the seal that goes on the outer tub,held in place by the band clamp that goes around the outer tub,make sure you mark where the top part of the tub fits into the bottom.Mark how far down it fits into the lower part.It can be a PITA to get the top part put back where it doesn't rub on the inner tub and make noise. kennyGF |
Post# 86493 , Reply# 6   10/2/2005 at 09:12 (6,777 days old) by juliaevan ()   |   | |
Thank you both very much. |
