Thread Number: 34101
Easy Spindrier stopped spinning |
Post# 512139 , Reply# 1   4/18/2011 at 11:07 (4,727 days old) by mickeyd (Hamburg NY)   |   | |
Is the basket nestled in all the way. Sometimes it will raise up a little and won't spin because it's off the gear. Can you remove the basket ? If so, when the basket it out, engage the spinner and see if the gear is turning. Haven't had one stuck permanently, so this is all I've got. Hope it helps. |
Post# 512141 , Reply# 2   4/18/2011 at 11:31 (4,727 days old) by gyromatic (St. Paul MN.)   |   | |
It will not turn at all.The basket comes out easily. Thanks,John |
Post# 512145 , Reply# 3   4/18/2011 at 11:54 (4,727 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 515022 , Reply# 4   5/1/2011 at 20:59 (4,714 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
I haven't seen an Easy since grandma's in the 50s but I vaguely remember how they work. Both sides run off a central motor by belts to clutches (what the handles turn on and off). It would be pretty surprising for the clutch to completely quit from one cycle to the next. That leaves broken belt as most likely. Hope that's it, by far the simplest thing that can go wrong.
