Thread Number: 34662
Maytag agi question
Post# 519833   5/22/2011 at 22:57 (4,712 days old) by aladude ()
What did the "load sensor" agitator in Maytag dependable care machines actually do? Was there any sensing of the load occurring at all? A relative has had one such machine since it was new in 1997 and I never thought to wonder about this name until I used it last weekend.
Post# 519840 , Reply# 1   5/22/2011 at 23:48 (4,712 days old) by arbilab (Ft Worth TX (Ridglea))
arbilab's profile picture
*I think* they're referring to the outer agi vanes being flexible rather than rigid. IMO marketing blew that feature out of proportion calling it "load sensing". IF that's what it's referring to.
Post# 519923 , Reply# 2   5/23/2011 at 10:24 (4,712 days old) by mixfinder ()
Load Sensing
Like every racheting agitator with short stroke action it requires the water level and load to be sufficient to hold the agitator corkscrew in place while it clicks and rachets to another half turn.  There is no sensor or magic that happens.  Just like a socket on a rachet.
Post# 519941 , Reply# 3   5/23/2011 at 11:43 (4,712 days old) by nmassman44 (Brooksville Florida)
nmassman44's profile picture
Not exactly....The Maytag LoadSensor is a different animal than what Whirlpool uses. The Maytag agitator uses a system that allows for the spiral to move more with larger loads and less or none with lighter loads. With big loads the spiral will move faster to drive the load into the base area. With lighter loads it will move with the base and ratchet only when it needs to.
Post# 520054 , Reply# 4   5/23/2011 at 19:06 (4,711 days old) by mixfinder ()
Different?
How is the function of the load sensor any different from a Sears Dual Action?  Does the Maytag have a drive system for the corkscrew that uses something other than dogs?
Post# 520057 , Reply# 5   5/23/2011 at 19:11 (4,711 days old) by redcarpetdrew (Fairfield, CA)
redcarpetdrew's profile picture
Actually, yes. The Maytag system used a series of 'marbles' to advance the corkscrew if needed. There was a 'clear' agitator that was for demonstration purposes when the agitator first came out. That's why the Maytag agitators make more of a clinking noise that would remind one of marbles...
RCD
Post# 520062 , Reply# 6   5/23/2011 at 19:23 (4,711 days old) by mixfinder ()
Thanks, Andy
I have had both the LAT series and a Norgetag and I was relieved they aren't as annoying as the clack, clack of the Whirlpool transmission and agitator.  I am glad I learned something.
Post# 520075 , Reply# 7   5/23/2011 at 20:18 (4,711 days old) by combo52 (50 Year Repair Tech Beltsville,Md)
MT LAOD SENSOR AGITATOR
combo52's profile picture
Yes the MT LS has a little friction in it so if it doesn't contact any clothing the top spiral section just moves back and forth with the bottom section. Bottom line it doesn't make any difference both the WP style and the MT style work very well, dual action agitators are the best thing that ever happened to top loading washers.
