Thread Number: 34717
Washer Miracle-TWICE in one day |
Post# 520579   5/26/2011 at 08:55 (4,716 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
ON the same machine! I was restoring my '56 Gyromatic ,complete motor set rebuild, new tranny seals , repair the wiring short created at the factory, rewire water valve. When TWO miracles happened! One when reinstalling the motor set , if you are familiar with the Bendix, you work from the back and then you need to go around the front and after the motor is mounted you have to install the drain pump hose to the pump! Well I get around to the front and the pump has mounted ITSELF ! I couldn't believe what saw so I took photographic evidence ! Second I was about to mount the back panel onto the machine when I realized I needed the screws across the basement. So I put the panel down walked away and realized the panel was standing ALL by Itself! Whoa! I took more photographic evidence. I would say this machine REALLY wants to get back to work, what do YOU think? |
Post# 520580 , Reply# 1   5/26/2011 at 08:56 (4,716 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 520582 , Reply# 2   5/26/2011 at 08:57 (4,716 days old) by Jetcone (Schenectady-Home of Calrods,Monitor Tops,Toroid Transformers)   |   | |
Post# 520586 , Reply# 3   5/26/2011 at 09:21 (4,716 days old) by golittlesport (California)   |   | |
Post# 520591 , Reply# 4   5/26/2011 at 09:53 (4,715 days old) by JaredH ()   |   | |
You might be haunted by a spritual helper! |
Post# 520637 , Reply# 5   5/26/2011 at 15:11 (4,715 days old) by gansky1 (Omaha, The Home of the TV Dinner!)   |   | |
