Thread Number: 34786
58 Frigidaire dishwasher progess report |
Post# 521355   5/29/2011 at 21:04 (4,714 days old) by turquoisedude (.)   |   | |
Oh so close...
The weather in Ogden was kinda iffy this weekend, so when it wasn't raining, we tried to get some garden work done. But when it was raining, I got to tinker with the 'work in progress' dishwashers! I really want to complete the 58 Frigidaire, so I started by putting the electrical components back into the machine. The timer assembly had been out of the machine since 2010 - I got it back in with no issues. The timer terminals are all very well-identified, so I was confident I was making the right connections. |
Post# 521356 , Reply# 1   5/29/2011 at 21:07 (4,714 days old) by turquoisedude (.)   |   | |
I somehow had the instinct to test the original water inlet valve a few weeks ago and found it was not working correctly. I swapped the original one with a more modern one - this one came from a 90s GE that had been removed from a rental property. It worked fine when I tested it, so I figured it would be fine.
Post# 521360 , Reply# 2   5/29/2011 at 21:24 (4,714 days old) by turquoisedude (.)   |   | |
So, I tried to run the machine through a cycle test and it was 'water water everywhere'! The flow of water through the original fill flume and air gap was more that it could handle... I was able to control the flow of water at the faucet, but this is not the ideal solution. As it is I could never safely build this machine in, so I am going to have to find a different solenoid... Any suggestions??
Post# 521361 , Reply# 3   5/29/2011 at 21:28 (4,714 days old) by turquoisedude (.)   |   | |
And now the good news...
I managed to run the dishwasher through three complete cycles (well, I shortened the dry cycles...) and it seemed to work just fine! The cycle reminds me of the KitchenAid of this era - a purge and flush, main wash, two rinses and a dry cycle punctuated by two drain phases after the dishes had a chance to 'drip'. I do believe that the Frigidaire Imperial models had a second wash but I can't remember if they had a third rinse... Anyway, my plans for next week will be to get the front panels painted - picture this in turquoise! Stay tuned... |
Post# 521367 , Reply# 4   5/29/2011 at 22:17 (4,714 days old) by appnut (TX)   |   | |
Paul, your machine's cycle sequence was pretty much what the spintubes back then were. The sequence you are referring to didn't happen until the next generation of spin tubes when the timer dial moved up to on the door panel and was a great big knob. That was probably the 1960 series. And oonly models with a "gated" detergent door had a 2nd wash. (meaning timed-opened detergent door). The basic models just had one grat big dimiple in the door where you put the detergent. However, even the basic model still had the same cycle sequence as the higher-end models with 2 detergent washes. purge/flush, wash, rinse rinse (which was a wash with 2nd detergent dispenser), and two final rinses and on into dry. I believe these only had one pump out during the dry cycle. Our 1959/1960 Waste King did the same thing during the dry cycle. |
Post# 522959 , Reply# 5   6/6/2011 at 19:26 (4,706 days old) by turquoisedude (.)   |   | |
Voice over: "When we last looked in on the garage in Ogden, the water inlet solenoid on the 1958 Frigidaire dishwasher was still causing an overflow at the air gap..."
Ok, so this week's episode was still about solenoids... OY! I found a solenoid from another abandoned GE dishwasher (a portable this time) so I tried it. Too much water. I tried swapping the solenoid from the 61 Whirlpool that did not seem to be letting enough water into that machine. Still too much water. I finally spent several hours taking the original Frigidaire solenoid apart to inspect it (managed to tear the diaphragm washer...GRRR!), got it back together, it leaked, and it still sent too much water into the air gap inlet... Hubby very wisely took me out to dinner at that point. So, Sunday morning, I figured the best way to solve the inlet overflow problem was to...take out the original air gap! Well, the son of a gun worked. Not pretty, not original, but by golly, it's water-tight! |
Post# 522960 , Reply# 6   6/6/2011 at 19:28 (4,706 days old) by turquoisedude (.)   |   | |
So, now I was ready to attack the real goal of the weekend - repainting the door and access panel.
Here's the before shot. Note the original white finish where the Frigidaire nameplate went. This post was last edited 06/06/2011 at 19:47 |
Post# 522961 , Reply# 7   6/6/2011 at 19:30 (4,706 days old) by turquoisedude (.)   |   | |
Post# 522962 , Reply# 8   6/6/2011 at 19:32 (4,706 days old) by turquoisedude (.)   |   | |
Post# 522963 , Reply# 9   6/6/2011 at 19:33 (4,706 days old) by turquoisedude (.)   |   | |
Post# 522965 , Reply# 10   6/6/2011 at 19:35 (4,706 days old) by turquoisedude (.)   |   | |
Post# 522967 , Reply# 11   6/6/2011 at 19:40 (4,706 days old) by turquoisedude (.)   |   | |
And the second thing I forgot about this machine - a wiring diagram! Not the complete one with schematics, but enough to clearly show where the wires go. I was lucky enough to get the electrical components back together without it, though!
So, next step will be reassembly and there will, of course have to be a wash test. However, I may debut this machine in a couple of weeks, when a couple of AWO members will be visiting Ogden... Stay tuned!! |
Post# 522972 , Reply# 12   6/6/2011 at 19:56 (4,706 days old) by RevvinKevin (Tinseltown - Shakey Town - La-La Land)   |   | |
Post# 523211 , Reply# 13   6/7/2011 at 21:19 (4,705 days old) by turquoisedude (.)   |   | |
Post# 523223 , Reply# 14   6/7/2011 at 22:03 (4,705 days old) by steved (Guilderland, New York)   |   | |
They made this model from 56 to 58 |
Post# 523224 , Reply# 15   6/7/2011 at 22:04 (4,705 days old) by steved (Guilderland, New York)   |   | |
the facts |
Post# 523226 , Reply# 16   6/7/2011 at 22:08 (4,705 days old) by steved (Guilderland, New York)   |   | |
A complete wiring diagram |
Post# 523305 , Reply# 17   6/8/2011 at 09:21 (4,704 days old) by turquoisedude (.)   |   | |
Post# 523520 , Reply# 18   6/9/2011 at 10:26 (4,703 days old) by mickeyd (Hamburg NY)   |   | |
Dry cycles are so boring! How cool to have a machine that comes back to life with the excitement of the pump.
It's great to see a spintube Frigi. I'm sure you like it. I'd love one.
Can't imagine why you'd paint it turquoise
It'll be beautiful.
EDIT: Once I posted and the icon came to life, I remembered your story about the Westy tangling all of your nice long sleeved dress shirts. |
Post# 523777 , Reply# 19   6/10/2011 at 15:00 (4,702 days old) by aldspinboy (Philadelphia, Pa)   |   | |
Post# 524170 , Reply# 20   6/12/2011 at 21:55 (4,700 days old) by turquoisedude (.)   |   | |
Post# 524171 , Reply# 21   6/12/2011 at 22:01 (4,700 days old) by turquoisedude (.)   |   | |
The finished product at last!
Not perfect, by a long shot...I managed to mess up the corner of the lower right hand side of the door panel - I had LOTS of fun getting the lower access panel back on the dishwasher. It took a few tries, but I finally did get it installed correctly. And I had a positive witch of a time getting the start pushbutton back into place.. BUT it's back together and it runs! The maiden wash should coincide with the visit of Mike and Darren, with any luck! |
Post# 524192 , Reply# 22   6/13/2011 at 00:12 (4,700 days old) by 69oyu812 ()   |   | |
Looks incredible Paul....well done! |
Post# 524194 , Reply# 23   6/13/2011 at 00:44 (4,700 days old) by PhilR (Quebec Canada)   |   | |
