Thread Number: 34837
Maytag dryer - Info Needed |
Post# 521936 , Reply# 1   6/2/2011 at 08:18 (4,708 days old) by turquoisedude (.)   |   | |
The timer may be OK - try setting it for 30 or 40 minutes and let the machine run for at least 10 minutes. If it still doesn't move, then there may be a timer issue...
I have a DE701 that I thought had a dead timer, too; turns it out it didn't when I did the above. If you can post the serial number here, one of the Maytag experts will be able to "decode" it and give you a date of manufacture for your dryer. These are sturdy machines - you may want to do some work on it (clean it up and re-oil the drum bearings) but it will be worth it! |
