Thread Number: 34870
Whirlpool DD Question |
Post# 522309   6/3/2011 at 16:49 (4,709 days old) by mrb627 (Buford, GA)   |   | |
Post# 522330 , Reply# 1   6/3/2011 at 19:32 (4,709 days old) by combo52 (50 Year Repair Tech Beltsville,Md)   |   | |
There is no adjustment possible and I have never seen a service pointer on this subject. If you have a bad knock on a DD washer make sure all three transmission mounting bolts are in place and tight. Other than that you can replace the complete trans or if you want to repair yours you can replace the agitator shaft which comes with the agitator final drive gear.
There was an adjustment on BD trans for this problem up and till about 1970, there was a large nut on the bottom of the trans if yours is adjustable. |
Post# 522341 , Reply# 2   6/3/2011 at 21:31 (4,709 days old) by mrb627 (Buford, GA)   |   | |
