Thread Number: 34891
Whirlpool DD |
Post# 522517 , Reply# 1   6/4/2011 at 19:40 (4,703 days old) by jlbrazil (brazil)   |   | |
Here it could spin like normal. CLICK HERE TO GO TO jlbrazil's LINK |
Post# 522521 , Reply# 2   6/4/2011 at 20:26 (4,703 days old) by limitededition ()   |   | |
Check clutch lining |
Post# 522532 , Reply# 3   6/4/2011 at 21:35 (4,703 days old) by pierreandreply4 (St-Bruno de montarville (province of quebec) canada)   |   | |
Might also be a motor problem i had a 1993 dd inglis whirlpool superb2 it did its wash cycle normaly but after the last spin i went to put the clothes in the dryer the washer did not drain or spin tryed setting the dial to the last spin so it would drain and spin there was nothing the motor had burn i had to drain the washer by hand
Post# 522548 , Reply# 4   6/4/2011 at 23:36 (4,702 days old) by yogitunes (New Jersey)   |   | |
Post# 522584 , Reply# 5   6/5/2011 at 06:49 (4,702 days old) by magic clean ()   |   | |
the agitator and inspect the basket drive block, basket drive shaft tabs and spanner nut. |
Post# 522617 , Reply# 6   6/5/2011 at 10:44 (4,702 days old) by jlbrazil (brazil)   |   | |
Thank you guys..I will tell this for him...thanks ALOT! ;) |
