Thread Number: 35019
What does the sun symbol mean on my siemens dryer? |
Post# 524131 , Reply# 1   6/12/2011 at 16:03 (4,672 days old) by aquarius1984 (Planet earth)   |   | |
Post# 524136 , Reply# 3   6/12/2011 at 16:25 (4,672 days old) by arbilab (Ft Worth TX (Ridglea))   |   | |
Post# 524137 , Reply# 4   6/12/2011 at 16:30 (4,672 days old) by aegokocarat (United Kingdom)   |   | |
nope, its just a sensor heat pump dryer |
Post# 524139 , Reply# 5   6/12/2011 at 16:33 (4,672 days old) by lavamat_jon (UK)   |   | |
Sounds like it calibrates the drying sensors... like on most sensor dryers.
Jon |
Post# 524141 , Reply# 6   6/12/2011 at 16:41 (4,672 days old) by aegokocarat (United Kingdom)   |   | |
thanks Jon! |
Post# 524142 , Reply# 7   6/12/2011 at 16:42 (4,672 days old) by aquarius1984 (Planet earth)   |   | |
Its just like a fine tuning thing like your TV would have.
What i call Iron dry may not be what you call iron dry or suitable for what your iron can handle for instance so it enables you to lessen or increase the drying levels within the settings. My microwave has this option to adjust cooking levels on its sensor cook programmes so that many tastes are catered for. it will define that level of sensitivty on all programmes so no need to re adjust. try it on a lower level and see how you get on with that first then if the results are not to your liking up it by one setting until you get the results you like. |
Post# 524146 , Reply# 8   6/12/2011 at 16:55 (4,672 days old) by aegokocarat (United Kingdom)   |   | |
Thanks guys! :) |
Post# 524156 , Reply# 9   6/12/2011 at 19:05 (4,672 days old) by Launderess (Quiet Please, There´s a Lady on Stage)   |   | |
Various fabrics will require different levels of remaining moisture to be properly ironed.
Generally linen should be quite damp, cotton less so and man made fibers should be removed from the dryer whilst barely moist (but cool) and smoothed into shape/hung to dry. If one were pegging one's laundry out on the line,one would take things down as they reached the proper level of dampness, the dryer has been designed to give users the ability to fine tune how "damp" things should be based upon their own preferences. |
