Thread Number: 35477
Speed Queen Woes... |
Post# 529701 , Reply# 2   7/9/2011 at 16:46 (4,667 days old) by pdub (Portland, Oregon)   |   | |
In your picture at the bottom left at the front is the pump. You could try loosening the thumb screw on the bottom of the pump, removing the clamp, then pull the cover down and off. Put a shallow pan under to catch any water that my come pouring out and have old towels ready. It sounds like there is an obstruction inside from what you describe and you may be able to clean it out and reassemble it. Take some pictures of the process and let us know how it turns out.
If it turns out the pump is shot there are replacements available. Here is one that is on ebay as we speak. Good Luck CLICK HERE TO GO TO pdub's LINK on eBay |
Post# 529702 , Reply# 3   7/9/2011 at 16:55 (4,667 days old) by yogitunes (New Jersey)   |   | |
I had a piece of metal, at the bottom of the outter tub, clogging the opening to the pump......once removed, all worked fine.......
you can also check www.easyapplianceparts.com... .....their in Canada....thats where I get most of my parts for my SQ these machines can also be gravity drained, pump not needed if you have a floor drain..... |
Post# 529745 , Reply# 4   7/10/2011 at 06:28 (4,666 days old) by mrb627 (Buford, GA)   |   | |
