Thread Number: 35616
Indesit WIB101 Running Amok |
Post# 531421   7/18/2011 at 16:14 (4,658 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Hi guys... thanks again for your comments on the previous thread 'Chuck Away Society". I decided to create a new thread as the focus has now shifted from the 'throw away society' to this washer's odd behaviour.
I made a video where you can see the action I've taken to solve the erratic motor operation of the Indesit front loader I salvaged... where you can also see some wash patterns... some I find rather unscheduled! It seems that the motor is suffering from a thermal cut out every now and again. As always, your input is most appreciated. Thanks :-) CLICK HERE TO GO TO Haxisfan's LINK |
Post# 531445 , Reply# 1   7/18/2011 at 17:39 (4,658 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 531534 , Reply# 2   7/19/2011 at 01:20 (4,658 days old) by dj-gabriele ()   |   | |
I must say that the machine is remarkably balanced when it stops and start spinning again! |
Post# 531555 , Reply# 3   7/19/2011 at 06:41 (4,657 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Austin... my thoughts entirely... but I cannot help being doubtful as I've never heard of a machine behaving like this due to worn carbon brushes! I strongly doubt it's the PCB. I'll get a new set of brushes sometime soon...
Gabriele... stunning isn't it? However, I can assure you that the machine would not even attempt to balance the load should have not been balanced when this was happening... in fact in one instance (which I didn't capture as I wasn't filming) the machine had a good share of thumping! That made me realise that these stops were utterly unscheduled! Those bathmats (and some grubby socks) were washed really well, so the machine did its job properly... however, they felt as if they had been washed on a synthetics cycle with a short 800rpm spin! |
Post# 531618 , Reply# 5   7/19/2011 at 14:12 (4,657 days old) by ultimafan ()   |   | |
For some reason, the Indesit's spinning behaviour seemed to remind me of Candy's when it would distribute for five seconds and zoom into the final spin. |
Post# 531679 , Reply# 6   7/19/2011 at 17:04 (4,657 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Thanks Alex! The last thing I would think of is that you made an idiot of yourself! This whole scenario leads me to think that other components might be involved... and you surely mentioned more technical bits than I ever did (now who's the idiot?).
I guess the only way to find out whether the brushes are responsible for this stop/start fashion is to replace the them... after all, the ones shown on the spares website's pictures are at least 5 times longer if not more! B.t.w. you won't believe the infinite range of carbon brushes that Indesit/Hotpoint have for their machines... each with a different price: I wonder if the pricier ones are deliberately made for cheaper models like this one to deter people from repairing them or it's just reverse psychology? |
Post# 531736 , Reply# 7   7/20/2011 at 06:43 (4,656 days old) by optima (Cumbria England)   |   | |
Just watched it i think it's more of a programming issue because it does everything it should do up to the final 1000 spin. Yes it does need new brushes but i think it will not solve this problem. If it was a problem with the tacho it would not have got right up to the final stage of the programme because it was spinning correct in between the rinse stages. Just as well you had a decent load of washing in it during this video. The out of balance sensor is none existent! One pair of jeans or some bathmats doesn't bare thinking about.
Post# 531882 , Reply# 8   7/20/2011 at 18:37 (4,656 days old) by Haxisfan (Europe - UK / Italy)   |   | |
Yeah... I don't think the machine 'realises' that is actually stopping... then it carries on spinning without balancing: most of the time it was balanced by sheer luck!
I received some feedback on YT about the luck of spring pressure on the brushes since they're rather worn, and this might cause them to detach from the commutator at high speed; I found that entirely possible... so, I'll see what will happen when I fit a new set of brushes next week. Thank you again everyone for helping me in my quest ;-) |
