Thread Number: 36022
Bosch New Line for 2011/2012 |
Post# 537053 , Reply# 1   8/15/2011 at 03:29 (4,637 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
This Photo is the dryer: Model WTY88700, with Heat pump & Self cleaning condenser |
Post# 537054 , Reply# 2   8/15/2011 at 03:33 (4,637 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
And now the non i-Dos washing machine: WAY32740 (as you can see the i-Dos buttons have been replaced with Auto Stain removal) (I wonder what the Siemens will be like) Please post your comments on these, and opinions:) |
Post# 537055 , Reply# 3   8/15/2011 at 03:35 (4,637 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
I suppose the Title of the Forum should have been 2011-2012-2013 as in the UK we may get them April/May 2012-April/May 2013! |
Post# 537063 , Reply# 5   8/15/2011 at 04:39 (4,637 days old) by logixx (Germany)   |   | |
These are pretty much the same as last year's models - nothing too exiting. New display and drum LED light on both the washer and the dryer and new doors. The dryer now also has speedPerfect. A full 8kg load spun at 1000 rpm takes 170 minutes to dry using ecoPerfect - wow. But these dryers are very energy efficient indeed and have an "improved cooling system" - whatever that means. Interestingly, the manual says to actually rinse the two lint filters as part of the regular cleaning. There is also now a 45 cm dishwasher with varioSpeed, 3rd rack and longer upper (middle) rack. A second spray arm was added under the rack so they could make it longer.
Post# 537070 , Reply# 6   8/15/2011 at 06:24 (4,637 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
I have seen those dishwashers as well, and think they are wonderful! I suspect two arms is more powerfull isn't it? Plus I have seen the new Siemens Tumble dryer on the IFA Berlin website, and it is rated A-60%! New washers are on there as well. |
Post# 537101 , Reply# 7   8/15/2011 at 08:39 (4,637 days old) by aquarius8000 ()   |   | |
Now they look good! |
Post# 537106 , Reply# 8   8/15/2011 at 08:52 (4,637 days old) by aegokocarat (United Kingdom)   |   | |
awful!! i perefer the current styling, i hope siemens stay the same :) |
Post# 537120 , Reply# 10   8/15/2011 at 10:20 (4,637 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
Siemens Heat Pump dryer Just thought I would get the photo of the A-60% Dryer! Seems to have the Dynamic wash load direction they use on the washing machines:)Maybe that's the trick to getting there A-60% (Bosch's are A-50%) CLICK HERE TO GO TO glenfieldmathk1's LINK |
Post# 537122 , Reply# 11   8/15/2011 at 10:26 (4,637 days old) by aegokocarat (United Kingdom)   |   | |
if i had that siemens dryer my mam would deffinantly have more bridget jones moments with it lol |
Post# 537126 , Reply# 12   8/15/2011 at 11:07 (4,637 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
Post# 537129 , Reply# 13   8/15/2011 at 11:11 (4,637 days old) by aegokocarat (United Kingdom)   |   | |
she is more used to a traditional timed dryer, yesterday she dident close the dryer door and she hit the start button and it bleeped and dident start so i closed teh door and then it started, she is still getting used to it :) |
Post# 537137 , Reply# 15   8/15/2011 at 11:34 (4,637 days old) by aegokocarat (United Kingdom)   |   | |
my dryer has an lcd screen, and if the door is open and you press start it will beep twice and the numbers on the screen will flash |
Post# 537138 , Reply# 16   8/15/2011 at 11:36 (4,637 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
Oh I thought the Heat pump ones had an LED Screen:) just on a orange background. Obviously I was wrong, well I think the new ones instead of flash will actually say on the screen 'Door open' or 'Door not closed' |
Post# 537165 , Reply# 17   8/15/2011 at 13:50 (4,637 days old) by logixx (Germany)   |   | |
Post# 537167 , Reply# 18   8/15/2011 at 14:11 (4,637 days old) by logixx (Germany)   |   | |
Yes, about the new motor on the washers: it's called EcoSilence Drive with BLDC technology and inverter technology. The dryer has a better door seal and design to further prevent lint for transferring onto the load when unloading and an improved filter that is "even more gentle to the laundry".
By the way, the A-60 % must be a type: both Bosch's and Siemens' homepages say the dryers are rated at A-50%. |
Post# 537359 , Reply# 20   8/16/2011 at 12:53 (4,636 days old) by dave886 (united kingdom)   |   | |
i like them the design, its very sleek, and it looks like its built to last but i can tell these going to cost a bomb |
Post# 537405 , Reply# 21   8/16/2011 at 16:47 (4,636 days old) by ariston4life ((Dublin) Ireland)   |   | |
Post# 537615 , Reply# 23   8/17/2011 at 15:10 (4,635 days old) by Rolls_rapide (.)   |   | |
Might mean "Brushless Direct Current" motor. |
Post# 538070 , Reply# 25   8/19/2011 at 11:13 (4,633 days old) by lavamat_jon (UK)   |   | |
Nice to see Bosch have returned to the old fashioned instruction booklets! |
Post# 538075 , Reply# 26   8/19/2011 at 11:47 (4,633 days old) by mieledani (Madrid, Spain)   |   | |
Where are these machines made? |
Post# 538443 , Reply# 27   8/21/2011 at 03:51 (4,631 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
I suspect Germany! Who Knows-though I suspect the Siemens is certainly made in Germany. |
Post# 538801 , Reply# 28   8/22/2011 at 14:36 (4,630 days old) by mieledani (Madrid, Spain)   |   | |
The question is: Is it possible to buy here in Spain a Bosch or a Siemens machine made in Germany (not in Spain)? I'm afraid that I prefer machines made in Germany!!! |
Post# 539154 , Reply# 29   8/24/2011 at 04:08 (4,628 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
Good question. I don't really know, I suspect they will all be made in Spain, though Could be they are made in Germany and Imported. I know some in Germany are made in Spain-so maybe some made in Germany are sold in Spain! |
Post# 540131 , Reply# 30   8/28/2011 at 11:54 (4,624 days old) by splittub (Europe)   |   | |
Do the new machines from Bosch still have a split outer tub, or are they welded like the ones in the new AEG Protex range? |
Post# 540543 , Reply# 31   8/30/2011 at 03:56 (4,622 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
Well that's another good question, I suspect it is the same tub that's used in the current Logixx machines! |
Post# 540624 , Reply# 33   8/30/2011 at 14:52 (4,622 days old) by dascot (Scotland)   |   | |
Cost doesn't equal quality, unfortunately. Though I suspect they have some things that the current machine doesn't, it may not cost much more to build, but they can charge more and make more profit from it... |
Post# 540626 , Reply# 34   8/30/2011 at 15:02 (4,622 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
@dascot Your right, but why are they offering 10 Years parts+Labour as opposed to just 2 years? As I said before, I think they are trying to outdo Miele! Alright they could just charge more to make profit. But certainly going to be better quality than those High Priced Hotpoint machines. |
Post# 540631 , Reply# 35   8/30/2011 at 15:20 (4,622 days old) by dascot (Scotland)   |   | |
I don't disagree. Will see when they get here what prices are and warranty is etc., as that may change between the continent and the UK... |
Post# 540643 , Reply# 36   8/30/2011 at 16:17 (4,622 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
It might do. They may not even come here to the uk, it will be a huge step from the current Logixx machines if they do! |
Post# 541995 , Reply# 39   9/6/2011 at 12:06 (4,615 days old) by joe_in_philly (Philadelphia, PA, USA)   |   | |
I used google translate to read the page in English - it changed the country of manufacture from Germany to USA!
CLICK HERE TO GO TO joe_in_philly's LINK |
Post# 542897 , Reply# 40   9/11/2011 at 03:23 (4,610 days old) by glenfieldmathk1 (Glenfield-Leicester-UK)   |   | |
No, they are made in Germany Even the pictures all state it. Think that's just a fault with Google Translate-My one doesn't even work any more! |
