Thread Number: 36037
How to tension the spinner belt on a Hoovermatic |
Post# 537310   8/16/2011 at 08:57 (4,634 days old) by supermaticjames (Donegal, Ireland)   |   | |
Afternoon all, Can someone guide me through this process please? Thanks, James. |
Post# 537311 , Reply# 1   8/16/2011 at 09:02 (4,634 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 537314 , Reply# 2   8/16/2011 at 09:27 (4,634 days old) by supermaticjames (Donegal, Ireland)   |   | |
Well luckily I have spare belts. Unfortunately I've moved both the motor and the mount have been moved. What is the proper position? |
Post# 537399 , Reply# 5   8/16/2011 at 16:23 (4,633 days old) by ozzie908 (Lincoln UK)   |   | |
Post# 537407 , Reply# 6   8/16/2011 at 16:55 (4,633 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 537922 , Reply# 7   8/18/2011 at 16:43 (4,631 days old) by keymatic3203 (Cardiff UK)   |   | |
Sorry I can't get to the Hoover twin tubs at the moment, but here are a few photos of the motor, and mounting arragement on a spin dryer. |
Post# 537923 , Reply# 8   8/18/2011 at 16:44 (4,631 days old) by keymatic3203 (Cardiff UK)   |   | |
See the three rubber mounts |
Post# 537927 , Reply# 10   8/18/2011 at 16:51 (4,631 days old) by keymatic3203 (Cardiff UK)   |   | |
and pump. |
Post# 537929 , Reply# 11   8/18/2011 at 16:55 (4,631 days old) by keymatic3203 (Cardiff UK)   |   | |
Hope this is ok tim, will try and remember to take some photos of the inside when I next get a hoovermatic out. mathew |
Post# 537930 , Reply# 12   8/18/2011 at 17:03 (4,631 days old) by macboy91si (Frankfort, KY)   |   | |
Post# 538392 , Reply# 14   8/20/2011 at 18:43 (4,629 days old) by anthony (uk)   |   | |
hi everyone just a tip that might help those of you that have later hoovermatics as you probably know vibration and noise can be a problem if a load is even slightly off balance i have fond memories of my mum filling the spinner to the top slaming the lid down then off into the garden with the first load not a second thought for the hoovermatic violently shaking itself ot death .After recently fitting a new pump to my 5090 i decided to try and calm the vibrations down a bit by stuffing some rubber treadair carpet underlay between both the wash and spin tubs and the cabinet i have to say the results are exelent the machine is much quieter when spinning you can actually hear it get up to speed then purr away at max revs.Im sure someone has already thought of this idea and im sure there are some of you that like that deafening noise an off balance load can cause well thats fine just to say my hoovermatic no longer sounds like a ford fiesta more like a BMW hope someone finds this usefull regards Anthony
Post# 1198153 , Reply# 17   1/28/2024 at 15:27 by anthony (uk)   |   | |
a spin can before tightening up the bolts. The paint tub holds the spin can in the right position allowing you to tip it up and tighten up those bolts
